Date: 25-05-26  Time: 21:03 pm
Author Topic: Gear lever  (Read 2379 times)
Dustydes
Gear lever
« on: 01 July 2016, 05:36:32 pm »
Hi all
Searched google with no luck.
How much free play should there be in gear lever.
Mine moves up about an inch of freeplay before I can then move up more to select gear.
It makes it hard to adjust for boot as I ride with toes on the pegs then slide foot forward to up shift.
I need the gap to slide boot in but then there is a lot of movement to select gear. If I reduce gap its hard to get boot to slide in nicely and I still have the same amount of free play.
Has the spring gone weak? does it hold lever in up position?
I have seen the R1 mod but is mine normal at moment ?
Des
stevegixer
Re: Gear lever
« Reply #1 on: 01 July 2016, 11:04:54 pm »
R1 mod ?
Dustydes
Re: Gear lever
« Reply #2 on: 02 July 2016, 08:42:19 am »
R1 mod ?
R1 has shorter shift linkage, less lift to select gears
Might have found the answer here, away on holiday today so cant check for a week or so
http://www.yamahafz1oa.com/forum/showthread.php?p=2425924
