Date: 11-04-26  Time: 05:11 am
Author Topic: Tap & Bolt Size  (Read 4278 times)
old son
Tap & Bolt Size
« on: 29 May 2016, 04:59:26 pm »
Can somebody remind me what size tap and what size Allen bolts I need to remove the AIS from above the exhaust pipes at the front of the engine.
Thanks
Cellarman
Re: Tap & Bolt Size
« Reply #1 on: 29 May 2016, 05:03:49 pm »
M8 tap & socket-cap bolts use a non tapered tap with plenty of lube
Follow Pat's guide here & you wont go wrong
old son
Re: Tap & Bolt Size
« Reply #2 on: 29 May 2016, 05:39:40 pm »
Thanks. How long do the bolts need to be?
Falcon 269
Re: Tap & Bolt Size
« Reply #3 on: 29 May 2016, 05:54:31 pm »
Sorry to contradict but I strongly recommend an HSS tapered tap to cut the thread in the stubs.  You need to cut the thread to about 1cm depth only, so a tapered tap will give you all you need and more with much less chance of snagging while you're cutting the thread. :)
old son
Re: Tap & Bolt Size
« Reply #4 on: 29 May 2016, 05:57:46 pm »
Thanks Mike
Cellarman
Re: Tap & Bolt Size
« Reply #5 on: 29 May 2016, 06:00:21 pm »
Sorry about that I meant to say tapered (brain fade) :lol
I used 8mm stainless ones from Ebay cost a couple of quid
Falcon 269
Re: Tap & Bolt Size
« Reply #6 on: 29 May 2016, 06:52:09 pm »
Brain fade?  Yup, get that all the time :D
old son
Re: Tap & Bolt Size
« Reply #7 on: 29 May 2016, 07:27:08 pm »
Ive just bought five from eBay for 99p!!! Prices must becoming down ha ha
old son
Re: Tap & Bolt Size
« Reply #8 on: 29 May 2016, 08:51:31 pm »
Do I need an M8 x 1.0, 1.25 or 1.5 tap?
mickvp
  • Global Moderator
Tap & Bolt Size
« Reply #9 on: 29 May 2016, 09:02:12 pm »
Iirc 1.25 is standard M8 pitch, but it doesn't matter really as long as you get the right pitch bolts to match :)
old son
Re: Tap & Bolt Size
« Reply #10 on: 29 May 2016, 09:28:23 pm »
Thanks.
RMT1983
Re: Tap & Bolt Size
« Reply #11 on: 29 May 2016, 09:37:15 pm »
ive got a set from Ivan that I wont be using............................ pm me if your interested mate
old son
Re: Tap & Bolt Size
« Reply #12 on: 29 May 2016, 09:54:01 pm »
I've ordered the bolts and tap from eBay now. Sorry
mick chiz
Re: Tap & Bolt Size
« Reply #13 on: 09 June 2016, 08:29:53 pm »
id try running a 6.8mm drill down 1st.its the right size for tapping m8x1.25 holes
