Date: 13-05-26  Time: 22:55 pm
Author Topic: Renthal bar ends  (Read 6235 times)
matt7chunk
Renthal bar ends
« on: 25 May 2016, 12:59:53 pm »
Hey,
I'm fitting renthal 758s soon and don't like the renthal bar ends they sell,  what other bar ends will fit the renthal bars ?
Thank you foccers  8)
Sent from my GT-I9300 using Tapatalk
tex
Re: Renthal bar ends
« Reply #1 on: 25 May 2016, 01:57:08 pm »
I think I had apprila ones on mine worked well, but any to fit 22 bars will work
mickvp
  • Global Moderator
Renthal bar ends
« Reply #2 on: 25 May 2016, 03:24:52 pm »
NorthWestern
« Reply #3 on: 25 May 2016, 06:02:43 pm »
I use the renthal plugs as they are clean and don't add width.  Think they are £3
Sent from my SM-G935F using Tapatalk
Val
« Reply #4 on: 26 May 2016, 11:00:44 am »
Hey,
No Renthal bars need special smaller diam bar ends. Mine Rentahl 758 was pretty non standard. Some say 13mm will fit. On mine 758 13mm was loose.
So I bought these: http://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/263556?r=GS&gclid=Cj0KEQjwvZq6BRC9kfq2zKfQ_94BEiQAOeUVC78-VOZJd2XBagvFYFQYtzBuQbTWb8Md1YqAG1A65v0aAphY8P8HAQ
And tweaked them with some plastic sleeves to fit. Actual diam was about 14.5 mm.
PieEater
« Reply #5 on: 27 May 2016, 07:55:22 am »
Take the Renthals to a machine shop and get them tapped out to take the OEM bar ends, cost you about the same as a cheap pair of bar ends but the OEM ones help noticeably with vibrations.
Arfa
« Reply #7 on: 28 May 2016, 08:38:48 am »
Got some R&G ones on mine, do the job and look alright. Like mini crash bobbins on bars. Do stick out a bit more than others shown here mind.
Sent from my HTC One X using Tapatalk
matt7chunk
« Reply #8 on: 05 June 2016, 08:54:28 am »
Ended up get these 13mm red ones from eBay,  bars great, no more wrist ache
celticdog
« Reply #9 on: 05 June 2016, 09:51:50 am »
Sweet! All you need is some R6 mirrors to complete the look  :)
matt7chunk
« Reply #10 on: 05 June 2016, 10:56:31 am »
I got some fazer thou  mirrors but I found them too big and a big buggy,  I was thinking r6 r1
« Reply #11 on: 05 June 2016, 11:48:03 am »
I have heated grips on my bike, presumably they'd need to be wrecked if i swapped bars?
matt7chunk
« Reply #12 on: 05 June 2016, 11:52:07 am »
If your careful with a small flat head screwdriver you can release the  old glue and wiggle them off
matt7chunk
« Reply #13 on: 05 June 2016, 11:53:30 am »
Or if you have access to a air compressor you can blast air underneath and slide them off
celticdog
« Reply #14 on: 05 June 2016, 12:04:17 pm »
if you can get some wd40 or similar in there (use the wee red straw that always gets lost!) they should come off with a bit of wiggling,
« Reply #15 on: 05 June 2016, 12:35:46 pm »
The supplied glue was rather useless so i used a heavier duty one, not sure if i'd be able to get them off in good condition, which is a bit of a conundrum as i obviously need them back on immediately.
« Reply #16 on: 05 June 2016, 09:51:11 pm »
Would you sell the Fazer 1000 ones or do a deal on them I have a set of short R1 mirrors in the garage.
Not OEM but in good nick, took them off a Fazer 400 a few years ago. Just noticed the mirror is a loose fit, but a dab of clear silicon would solver that everything thing else is fine.
sinto
« Reply #17 on: 05 June 2016, 10:28:58 pm »
Switch them onto highest setting to get glue warmed up, try moving the grips, although you used stronger glue they should still move slightly then you can use feeler gauges which won't damage the grips, other thing that is of use is a metal coathanger.
matt7chunk
« Reply #18 on: 05 June 2016, 10:57:31 pm »
I'm afraid they have found a new home already unfazed,  but I may be interested in your mirrors when payday comes around again
