Date: 06-05-26  Time: 08:42 am
Author Topic: front pads and fluid change  (Read 7492 times)
celticdog
« on: 20 May 2016, 10:06:58 am »
Hi guys got new galfer pads so fitting this weekend.  :thumbup I've a couple of quick questions for the foccer font of all knowledge! Is it worth me changing from dot 4 to dot 5.1? I use the bike for commuting any thoughts? Also, how much fluid will I need- would a 500ml bottle do or will I need a full litre? Cheers . . . Fellas  :rollin :rollin :rollin
Re: front pads and fluid change
« Reply #1 on: 20 May 2016, 12:48:31 pm »
Blatantly says only use Dot 4 on the master cylinder cap, and the brakes are pretty awesome enough using that, so I don't see why you'd need to try anything else?
It's not exactly expensive stuff, just get a litre so you can bleed the brakes properly, always better to have too much than not enough.
celticdog
« Reply #2 on: 20 May 2016, 12:52:10 pm »
Yes dot 4, just wondering if anyone has tried the dot 5.1 mod and how've they got on with it?
BBROWN1664
« Reply #3 on: 20 May 2016, 02:22:23 pm »
5.1 is more for racing. A lot more absorbent to water etc so needs changing more often.
In reality, it is no different from DOT4 in use on road bikes.
« Reply #4 on: 20 May 2016, 03:47:16 pm »
Someone has tried it 'cos I read it on here somewhere in the last few days, but not sure who it was?
Found him  :)
http://foc-u.co.uk/index.php/topic,20089.0.html
triker
« Reply #6 on: 20 May 2016, 08:45:13 pm »
Dot 4 500ml enough when I did mine...
kgjersda
« Reply #7 on: 28 May 2016, 09:35:05 pm »
Found him  :)
The guy from the other thread here :)
The brakes are working 100%, no problems with DOT 5.1 so far (800km). I'd like a little more bite from the brakes, but thats probably just worn out pads.
I had no real reason to use 5.1 over DOT 4. Just wanted to try it out.
celticdog
« Reply #8 on: 31 May 2016, 08:48:11 pm »
Glad to hear it works ok. In the end I chickened out and went for dot 4  :\
But I'm going to use it on the rear when I next change the pads  :)
« Reply #9 on: 01 June 2016, 05:51:50 am »
Do you really want 'more bite' on the rear?
I can understand trying it out at the front, but personally i wouldn't bother using it on the rear just for every day riding.
celticdog
« Reply #10 on: 01 June 2016, 08:09:37 am »
I'm strictly old school when it comes to braking darrsi, 80% front 20% rear rising to 50/50% in extremely wet road conditions  :)
JoeRock
« Reply #11 on: 01 June 2016, 08:28:54 am »
Brake fluid will make sod all difference to the bite (comparing 5.1 to 4, I don't mean comparing old to new fluid). Main difference is 5.1 has a higher boiling point, hence why its used on race bikes - you'll never get near the temperatures needed to boil fluid on the road unless you have a serious issue with your braking system. Downside is as pointed out its considerably more hygroscopic so will need bleeding more frequently, which is a bit pointless on a road bike too!
« Reply #12 on: 01 June 2016, 10:00:07 am »
Sounds like unnecessary hard work to me, for no real gain at all.
