Date: 14-05-26  Time: 05:36 am
Author Topic: BMW S1000RR rear shock question  (Read 11558 times)
joebloggs
Re: BMW S1000RR rear shock question
« Reply #25 on: 08 June 2016, 10:00:39 am »
Take off the shock and turn the fork 180 degrees to allow easier adjustment of the rebound otherwise it will be obscured by the exhaust
Thanks
Had turned it once but came back from the engineer who fitted the spring pointing in the exhausts direction. TBH one concern I do have is re the 16kg spring. No static sag (bikes very light) and hardly compresses when I sit on it, going to take some mighty bump in the road to bottom this one out.
« Reply #26 on: 08 June 2016, 10:34:59 am »
Yep, You are going to have a solid ride, that is about 15% stiffer than standard on the 600
JoeRock
« Reply #27 on: 08 June 2016, 02:30:13 pm »
That is not going to handle right I think - that spring seems extremely stiff for your weight. Also concerned that you've put a much stiffer spring on than the shock was designed for - I doubt the damping is going to be up to the job of controlling the shocks movements with that stiff a spring!
joebloggs
« Reply #28 on: 08 June 2016, 06:26:17 pm »
Yeah, I understand the theory, thing is, I don't really give a dam, it looks about right, and, in my book, that cant be far off.
JoeRock
« Reply #29 on: 09 June 2016, 12:37:33 pm »
Fair enough if you're wanting to put the bike on a plinth and look at it, but I wouldn't want to ride it!
joebloggs
« Reply #30 on: 09 June 2016, 05:14:18 pm »
Would sooner have an over firm shock than one that bottomed out on every bump in the road.Front ends most important to me and the SRAD forks got some pretty decent press in their day
