Date: 09-04-26  Time: 18:44 pm
Author Topic: Home made chain riveter!!  (Read 1853 times)
chunk166
« on: 09 March 2016, 06:27:32 pm »
Ok Guys 'n' Girls, I have made my own chain riveting tool thanks to Youtube for some ideas  :lol  Now as i like to do as much of my own work on my bike as i can (I'm a tight Foccer!) I have added a couple of pics & i just want to ask you if you think that it'll do the job!!! :eek :eek :eek
Thank you for your opinions in advance   :D :D
pilninggas
Re: Home made chain riveter!!
« Reply #1 on: 09 March 2016, 06:44:30 pm »
It might work. Those generic chain tools have presses that fit 5/8 chain sideplates properly so the process does not deform the sideplates or crush the o-rings. I tend to only use a chain tool to withdraw the pins from a rivet on the chain I am replacing (having ground the tops off) and to press the new link on (I wonder if your tool will do this). To peen the pins over on the new soft link I put a heavy hammer behind it and use a punch to peen 4 edges over, I then check with a caliper the peening has worked and the sideplate is secure.
chunk166
« Reply #2 on: 09 March 2016, 06:56:07 pm »
I have a tool to push the sideplate on, i made this as the link supplied is a hollow ended & i am hoping that this will open (flange) the pins out, obviously i will check with a vernier caliper as to make sure its enough to make it safe!  :eek
celticdog
« Reply #3 on: 09 March 2016, 07:13:11 pm »
needs more duct tape  ;)
Val
« Reply #4 on: 09 March 2016, 07:18:38 pm »
Or instead of riveting you can use the duct tape directly with the chain. Problem solved.
chunk166
« Reply #5 on: 09 March 2016, 07:26:09 pm »
I've run out of duct tape, was thinking of using blu tack but i'm not sure its strong enough  :lol
