Date: 04-05-26  Time: 07:52 am
Author Topic: Blue dot rear brake  (Read 1853 times)
msewelly
Blue dot rear brake
« on: 03 March 2016, 08:16:24 pm »
Hi,
Doing a bit of maintenance work on the rear caliper. The rear caliper has clearly not seen a good clean in a while and has a fair amount of corrosion. Even the retaining pins were a huge task to remove, one piston was sticking which I've managed to free up with lots of cleaning and greasing. A question I do have is how do I remove the corrosion on the inner part of the pistons, Its most likely only surface rust but I'd rather remove it to stop it worsening.
Thanks!
Falcon 269
Re: Blue dot rear brake
« Reply #1 on: 03 March 2016, 08:48:22 pm »
Remove and clean the pistons, check the caliper bores and replace the pistons.  Probably worth fitting new seals while you're at it.
