Date: 07-05-26  Time: 09:57 am
Author Topic: Side Stand Switch  (Read 14866 times)
Re: Side Stand Switch
« Reply #25 on: 24 March 2016, 05:25:33 pm »
I've not got round to doing this yet as I've had a dodgy back, but was hoping to try and change it tomorrow for the replacement one I bought.
Only thing is, the more I look at it, it just seems to be in a complete bastard of a place to actually get near it, to whack the screws with an impact driver for instance.  :smash
Am I missing a simple trick or something, or is it really just in a nasty position with the exhaust in the way as well?
« Reply #26 on: 24 March 2016, 09:44:51 pm »
Best of luck  :'(
His Dudeness
« Reply #27 on: 24 March 2016, 10:26:57 pm »
If it cuts out and leaves you stranded anywhere disconnect the switch from the loom and bridge the connector with a bit of wire and you'll be on your way ;)
« Reply #28 on: 25 March 2016, 04:46:04 am »
Best of luck  :'(
When i hear things like that from you, i know i'm in trouble.  :look
After i got home from work yesterday i got a new can of brake cleaner out and thought i'd degrease it while it was raining in the hope the rain would dilute the mess i was gonna make.
I probably should put it on the centre stand, although i dunno how much that would've helped either, but i could barely even get close to it to spray the chain lube off.
Whoever has the job of fitting them either has first go on an upside down empty frame, or is standing in a pit.  :groan
« Reply #29 on: 25 March 2016, 04:58:14 am »
Yeah, i found a YouTube video on how to basically hotwire it, by either bridging the connector like you say, or even cutting the wire and joining it, which is the same thing. I also read on an old post from years back to just remove the switch and tie it somewhere safe away from the stand, but if i could do that then i'd just put the other one back on.
I'll stare at it for a bit longer, and if i come up with something imaginative i'll let you know, otherwise it'll have to go down to the mechanic.  :\
Judging by the hole size in the new switch, they are M5 screws, and i've managed to find some stainless cap head screws at work in slightly different lengths to have on hand if i do ever manage to remove it.
Jules-C
« Reply #30 on: 25 March 2016, 07:01:40 am »
The secret is to do what they do in the factory.  Take the engine out then you've got good access to change the switch and once that's done put the engine back in the frame!
When mine failed I ended up cutting/smashing the old switch to remove it and using allan bolts when putting the new one in since you can't get a screwdriver on the screw heads
« Reply #31 on: 25 March 2016, 12:30:17 pm »
Yeah, i'm starting to realize that "secret".  :'(
I've cleaned up the whole area of chain lube so at least i can see it now, and now it just looks like a very unappealing job.
I'll stare at it a bit longer then decide what to do next.  :(
« Reply #32 on: 10 April 2016, 07:40:10 am »
Just to let you know, i cleaned up the area of the side stand switch with plenty of brake cleaner, and the scenario now is that i have to start the bike with the side stand up, but once started it does let me put the stand down and remains running okay so i can let the engine warm up without being on the bike.
It still won't start with the stand down though, the bastard.
Although not ideal, it's a situation that i can more than deal with for now.
I still have a new switch at the ready, or a pair of cutters so i can hotwire it if necessary though
« Reply #33 on: 03 May 2016, 03:51:42 pm »
I know it's not ideal, but to get me out of shit for now I have followed the side stand switch up to behind the left side panel and used a Scotch Lock cable joiner to basically "hotwire" the cables together and bypass the side stand switch for now.
I went to unplug the side stand switch plug and found that to be in a stupidly difficult place as well, so this fix will do for now.
His Dudeness
« Reply #34 on: 03 May 2016, 06:28:13 pm »
Don't ride off with your sidestand down :lol
« Reply #35 on: 03 May 2016, 08:15:59 pm »
I'm paranoid about that now, did it many years ago on a KMX, it ain't fun.
dublet
« Reply #36 on: 03 May 2016, 09:06:49 pm »
Scotch locks don't insulate well. If you can, just solder it properly.
« Reply #37 on: 03 May 2016, 09:44:03 pm »
It was a way of trying/testing it out without chopping the wires up for fun.
Now i know it works i can consider my next move.
His Dudeness
« Reply #38 on: 03 May 2016, 11:03:15 pm »
I'd use a short bit of wire and crimp two spade terminals on either end and connect it into the block connector. Probably not the correct thing to do but it'll work reliably and when you want to replace the switch properly the connector and loom are all still original
« Reply #39 on: 04 May 2016, 09:48:26 am »
That was the actual plan, but i couldn't figure out how to get anywhere near the plug, so went in to Plan B.
