Date: 21-04-26  Time: 22:01 pm
Author Topic: Led indicators flashing too fast  (Read 4093 times)
nickodemon
« on: 06 February 2016, 04:42:35 pm »
I fitted a set of led indicators  with load resistors for each indicator (fleabay) to slow the blink rate, but they are still too fast. How do i get them even slower? More load  resistors? I have never had this issue with any of my other bikes.. Is this a common fazer issue?
Woodzey80
Re: Led indicators flashing too fast
« Reply #1 on: 06 February 2016, 04:59:59 pm »
Buy the proper led relay, there on fleabay aswell
nickodemon
« Reply #2 on: 06 February 2016, 05:02:29 pm »
Is the fazer relay two pin or three pin
Woodzey80
« Reply #3 on: 06 February 2016, 05:04:10 pm »
I forget now, just get the seat off & pull the relay out to check
nickodemon
« Reply #4 on: 06 February 2016, 05:07:24 pm »
I'm out at the moment. I will check when i'm back. I didn't think the bike required an led relay when i have fitted inline led indicator resistors to each indicator.
Woodzey80
« Reply #5 on: 06 February 2016, 05:31:45 pm »
U need to proper butcher ur oem loom fitting them resistors & I hate that. Keep things simple (plug & play) abit more expensive but a better job !
kitcrazy
« Reply #6 on: 06 February 2016, 05:54:49 pm »
Anyone got any link's for some plug and play indicators please?
Smurfbud
« Reply #7 on: 06 February 2016, 08:37:08 pm »
you can get dual relays which will work with both normal and LED indies .....
http://www.ebay.co.uk/itm/400225499951?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
hope this helps
nickodemon
« Reply #8 on: 06 February 2016, 08:53:30 pm »
I cut the wires close to the harness, so the original indicators can have bullet connectors attached if i want to reconnect them. The thing is i have fitted the inline resistors, but they still flash too quickly. I don't get it? If i buy an led flasher unit, that means i will have resistors for the indicators and an led relay. I should only need one or the other....
Woodzey80
« Reply #9 on: 06 February 2016, 10:32:22 pm »
You should only need one or the other, are the resistors you fitted polarity sensitive do you know ?
nickodemon
« Reply #10 on: 06 February 2016, 10:35:44 pm »
I have tried them both ways round. If they are connected the wrong way round the indicators don't work. They have red and black wires so red's positive.
nickodemon
« Reply #11 on: 07 February 2016, 11:23:15 am »
If i turn the hazard lights on they flash at correct rate.... The relay under the seat is not like the ones in the links it has a connector with 2 pins
nickodemon
« Reply #12 on: 07 February 2016, 01:21:01 pm »
The inline indicator resistors don't work, so i fitted an led relay and hey presto. I firstly left the inline resistors in place but noticed the indicators were quite dim at tick over, so i removed them and the flash rate is the same, but they are brighter. Happy days.. Inline resistors in bin.
Woodzey80
« Reply #13 on: 07 February 2016, 02:18:55 pm »
Glad u got it sorted ! I was out of ideas
nickodemon
« Reply #14 on: 07 February 2016, 05:16:14 pm »
Cheers for your help... I bought the resistors from China ages ago.... I should know better :lol  Here is a link to the sh*t resistors, so no one else buys them.   http://www.ebay.co.uk/itm/262091968917
