Date: 22-03-26  Time: 16:06 pm
Author Topic: FZ1 footpeg spring  (Read 2219 times)
Streetbudgie
FZ1 footpeg spring
« on: 20 January 2016, 06:20:52 pm »
The spring in my left hand footpeg broke tonight so the peg just flops up and down now. I had a look and it seems that the peg is held in the bracket by a non removable fixing?
Any ideas if it's possible to replace the spring?
lew600fazer
Re: FZ1 footpeg spring
« Reply #1 on: 20 January 2016, 11:05:57 pm »
Easy , the pin is just a riveted end , disc grinder will do the job in seconds, carefully grind away the from the underside of the pin  , tap the pin out , get a new spring and just get a Cap head stainless Allen bolt and a lock nut. Add a drop of Locktite Blue and tighten it up until the peg will not overcome the tension of the new spring, back the nut off a tad until the spring tension is sufficient to over come the resistance so the peg will snap back. I fitted a lowering kit set of pegs to my FZ1 so I know this method will work .
Lew
Gary
« Reply #2 on: 21 January 2016, 11:35:15 am »
I had to replace mine last year for the same reason. I bought a sping/footpeg set off Ebay and fit it handy enough.
Something like this
http://www.ebay.co.uk/itm/Foot-pegs-Front-Footrest-For-Yamaha-FJR1300-FZ1-FZ6-FZ6R-FZ400-xjr1200-xjr1300-/391007443653?hash=item5b09dc1ac5:g:CTgAAOSw7ThUlRFG
Streetbudgie
« Reply #3 on: 21 January 2016, 05:58:48 pm »
Cheers for the replies guys, problem I have is that I'd have to lay out for a grinder so I'm thinking it might be easier just to replace the footpeg complete with spring.
I'll see if anyone has one for sale.
« Reply #4 on: 21 January 2016, 07:26:06 pm »
If you have time you could use a file :lol
