Date: 08-03-26  Time: 03:20 am
Author Topic: rear wheel bearings..  (Read 2664 times)
speirsy1810
« on: 25 November 2015, 09:19:47 pm »
Hi.......just picking fzs1000 riders brains...i need to get new rear wheel bearings.....where is the best place to get them from...i have no problems fitting them,
ta
esetest
Re: rear wheel bearings..
« Reply #1 on: 25 November 2015, 09:50:25 pm »
I got mine from Wemoto .
AyJay
« Reply #2 on: 25 November 2015, 09:55:59 pm »
I got a set from Markman Industrial. Or was it All Balls Racing. If forget.
If a bearing has failed, the roller caged one is a bastard to remove. It kind of welds itself into the aluminium of the wheel. Good luck!
« Reply #3 on: 25 November 2015, 10:17:22 pm »
The needle roller one does not normally give trouble unless the right side one is totally focced.
Replace the external right seal when replacing that bearing
Marksmans or WeMoto is where I usually get mine if I cannot get them in the local bearing shops
PaulSmith
« Reply #4 on: 26 November 2015, 10:33:28 am »
Marksman does the kit with everything you need. They have changed their website so it is much harder to find, but the kits you want have the codes 'YA001' for the rear wheel bearings and seals and 'YA002' for the sprocket carrier.
http://shop.marksman-ind.com/ya001-rear-wheel-bearing-kit-fazer-fzs-1000-01-05-yzf-r1-98-01-yzf-r699-02-20-p.asp
http://shop.marksman-ind.com/ya002-fazer-fzs1000-01-05-sprocket-carrier-bearing-kit-22-p.asp
bowen93
« Reply #5 on: 26 November 2015, 11:40:07 am »
i bought the kit from marksman also. good prices way cheaper than yamaha
speirsy1810
« Reply #6 on: 26 November 2015, 04:16:32 pm »
i hope not...but thanks..
speirsy1810
« Reply #7 on: 26 November 2015, 04:18:17 pm »
thanks for all your assistance....very helpful....
nickodemon
« Reply #8 on: 27 November 2015, 02:24:55 pm »
+1 Marksman
