Date: 18-04-26  Time: 14:56 pm
Author Topic: Engineers - what drill bits  (Read 3360 times)
locksmith
« on: 25 November 2015, 09:27:25 am »
Need recommendations for HSS drill bits, just regular sizes ie. 2 - 12mm
Used Rawlplug for many years but they've obviously changed something as they blunt and snap real easily nowdays.
So what brands are good?
davey boy
Re: Engineers - what drill bits
« Reply #1 on: 25 November 2015, 09:53:22 am »
I use Dormer at work. They work well on exotic stainless steels so should be good for you
mickvp
  • Global Moderator
« Reply #2 on: 25 November 2015, 10:48:44 am »
we use sandvik, seco, and walter in work. sandvik and walter are ok (I think they are the same company now), but seco are cheap sh*t.
I should point out that most of the tools we use in an industrial engineering environment are crown-loc drills now (the shaft is permanent and you just replace the tip of the drill).
Frosties
« Reply #3 on: 25 November 2015, 10:57:34 am »
I've sat with these for a while now - do the job for me every time
http://www.amazon.co.uk/Piranha-1-10mm-Metal-Bullet-Pieces/dp/B007FUF9F4
celticdog
« Reply #4 on: 25 November 2015, 11:00:08 am »
+1 for Dormer, long live the Jobber! Of course it all depends on what you're drilling.
locksmith
« Reply #5 on: 25 November 2015, 12:15:05 pm »
Dormer thats a blast from the past, used to use them years ago and I can get them trade so I'll give them a try.
I use the bits every day on various lock fitting/drilling duties
lew600fazer
« Reply #6 on: 26 November 2015, 12:11:45 am »
A lot of the time it is not the drill that is the problem but the operator. Depending on what you are drilling it is down drill head speed, cooling fluid being used, or lubricant at the drill head. Most drill failures are down to not letting the bit do it's job, as in drill!!, not trying to punch the hole through.
slimwilly
« Reply #7 on: 26 November 2015, 05:43:21 am »
Yes. True. S low head speed is a must.
johnakay
« Reply #8 on: 26 November 2015, 10:25:59 am »
 on harden steel you need to keep the drill sharp and correct speed as well as lube, I use Rocol lube.
stinks when hot but does the job.
http://www.ebay.co.uk/itm/Rocol-Sapphire-Precision-Lube-400ml-34341-ROC34341-/272035358976?hash=item3f56922900:g:GWsAAOSwYHxWOIfo
locksmith
« Reply #9 on: 27 November 2015, 11:54:44 am »
So is holding the battery drill like a gun slinger not the way to go?  :lol
Frosties
« Reply #10 on: 27 November 2015, 12:31:03 pm »
Nope! Nor is it cool to pretend you are Robocop  :lol
bobdog
« Reply #11 on: 27 November 2015, 02:18:19 pm »
if your drilling stainless steel you can get drill bits for drilling stainless steel, not much more expensive realy.
