Date: 14-05-26  Time: 12:45 pm
Author Topic: Where can I get valve shims in 0.01mm increments?  (Read 6433 times)
roxburd
« on: 15 November 2015, 10:00:51 pm »
Hi there,
Does anyone know where I can order valve shims in 0.01 increments rather than the 0.05 increments you get on most sites? The acceptable range is 0.04mm (0.21 to 0.25) so ordering a 0.05 smaller shim will take me from just under tolerance to almost over.
Cheers,
Dave
roxburd
Re: Where can I get valve shims in 0.01mm increments?
« Reply #1 on: 15 November 2015, 10:03:19 pm »
Alternatively, does anyone have a 1.89 they don't need?
Cheers
sadlonelygit
« Reply #2 on: 15 November 2015, 10:31:31 pm »
in the past i have faced shims down to size. the good news is that they harden when machined so no worries about them going out of spec. i doubt you'll get shims in 1/100th of a mm increments anywhere!
mickvp
  • Global Moderator
« Reply #3 on: 15 November 2015, 11:39:01 pm »
Not u less you cut up a feeler gauge, but I don't think it's advisable :lol
« Reply #4 on: 16 November 2015, 12:37:50 am »
Not possible to get and only as sadlonelygit says if you grind them down.
Have you checked all the shim sizes as you might be able to swap some around to get the clearances close to what you need.
The size etched on the shim is not always 100% accurate and you would be well advised to check them with a micrometer.
I will check my stash tomorrow and see what I have close to 1.89.
Note:-
The specs for the exhaust valves is 0.21 to 0.30 not 0.21 to 0.25 as stated in the Yamaha service manual and the Haynes manual.
roxburd
« Reply #5 on: 16 November 2015, 08:44:48 am »
Note:-
What!!?? Is that right??? Where does that come from if Yamaha and Haynes say .21 to .25? Not that I doubt you... but...
I only have one outside spec and that gap is too small so it needs doing anyway.
Great idea to swap them round though - none of the others need doing but a swap could avoid the need to get a new one and even out the gaps across all the valves.
If I do still need a specific 0.01 multiple I guess I'll call the dealers in the area - the bikes roll off the production line with 0.01 multiples so I guess the dealers will have accumulated them as they do services...
But I'll look at a swap first, thanks unfazed.
sadlonelygit
« Reply #6 on: 16 November 2015, 11:40:17 am »
having just re-read your post............if the yamaha tolerance is 0.04, then they only need to produce 0.05mm shims as 0.21 is in tolerance!
most bikes don't need touching until 40k plus anyhow, so a valve at bottom limit should be fine for 12k+
« Reply #7 on: 16 November 2015, 07:10:06 pm »
Both he Yamaha service and Haynes manual are both confusing because in one place it says 0.25 and another it say 0.30.   :'(
The early 98 R1 service manual say 0.21- 0.30 and the EXUP service manual is the same
I rang Yamaha Ireland (did not really believe them) and also rang Yamaha UK and both said the FZS1000 are 0.21 - 0.30 ex  :eek
When told this I checked with a few different mechanics and all said the same, early R1s and Fazer 1000 5 valve heads are 0.21 - 0.30.
I have always set any 5 valve heads between 0.21 to 0.30, my own included without problems.
On the shim size, the nearest I have to 189 is a one marked 190, but measures between 190 and 191on the micrometer
Might write to Haynes out of curiosity  :b
« Reply #8 on: 17 November 2015, 07:18:08 pm »
 Reply from Haynes
Dear Mr Duggan
The difficultly here is that the discrepancy exists in Yamaha’s own literature.
My view is that an exhaust clearance range of 0.21 to 0.30 mm has the same tolerance range as for the intake valves and that if you aim for a clearance of 0.25 mm you would err very slightly towards the tighter end of the range. Unfortunately without access to the factory there’s little we can do to confirm this.
[size=0pt]Penny Cox[/size]
[size=0pt][/color]Motorcycle Editorial Manager[/size]
[size=0pt][/color]DDI No: 01963 442044[/size]
[size=0pt][/color]e-mail: pcox@haynes.co.uk[/size]
roxburd
« Reply #9 on: 17 November 2015, 07:52:46 pm »
I generally prefer the tighter end of the range, myself...
« Reply #10 on: 17 November 2015, 09:54:36 pm »
 :lol
roxburd
« Reply #11 on: 09 January 2016, 02:10:22 pm »
So I went to the local independent mechanic (Chris Self, Ipswich) and he loads of all sizes - and did a handy swap-for-free deal too.
After bringing that one vale clearance into correct range, changing plugs and cleaning air filter the delayed pick-up problem is gone but an old problem is still there - if I accelerate moderately at about 15mph in 2nd gear out of a bend I get a weird noise that sounds like some slack in the transmission slapping about. Pulling away from the small roundabout at the end of my road is the litmus test - always happens. So I'm synchronising the carbs - simple job, done it loads of times before... but on the Fazer - NO SYNC SCREWS!!! They're not where the Haynes manual says they should be and I just can't find them!!! What's going on there then!!?? The carbs do need balancing as they're a bit out and it may solve the slapping. But I can't find the bloody screws - a simple job is impossible. How do the bike designers manage such a shitty trick!!??
It's a 2001 FZS 1000
Any advice much appreciated!!
Dave
roxburd
« Reply #12 on: 09 January 2016, 02:33:17 pm »
Ah, found 'em! Flipping heck they were where Haynes said they'd be, just about a foot behind a gap too small for light to pass through... slight exaggeration but I do need to buy a new screwdriver with the reach to get at them!!
Great photos for anyone who needs help - http://www.cartestsoftware.com/fz1/carburetorsynchronization.html
Dave
