Date: 20-04-26  Time: 09:28 am
Author Topic: New computer help  (Read 9804 times)
Frosties
Re: New computer help
« Reply #25 on: 06 November 2015, 09:13:21 am »
I love PC's .......
Phoenix
Phoenix
No shit Deadeye. Water cooling.....etc That's a cracking bit of kit  :eek
BBROWN1664
« Reply #26 on: 06 November 2015, 09:16:56 am »
8GB with an SSD will be faster.
« Reply #27 on: 06 November 2015, 09:22:45 am »
Thank you for your help
I think I may do it that way because I can easily add extra memory later, I use acronis true image for backups so I could swap the drive later but swapping the HD later will be a bit more of a faff and then also worrying about people accessing my "deleted" drive if I try to sell the old HD
Val
« Reply #28 on: 06 November 2015, 11:04:06 am »
There are some details here - if you are concerned about security do not buy SSD -the information never gets really deleted there and at some point if you change it somebody can read it.
That is the last thing to worry about SSD though - some SSD devices from some manufacturers have really bad reliability problems.
Generally SSD technology has very low endurance compared to HD - in the magnittude of 100x-200x worst.
Also it is very expensive per Mb.
For above reasons I will never install and rely on SSD only. IMO is better to have small and good manufacturer quality SSD for the operating system and the programs only - this way your PC will start and work faster.
But keep high volume and important data on a HD for reliability and cost reasons.
Backup is fine but usually disks fail before you do backup and you loose all that has not been backuped yet.
Even RAID 0 or RAID 5 configuratin HDs. Raid means several HD drives working together if one disk fails you do not loose your information and can change the disk and continue.
This way I know my information is protected.
Think about it are you ok if you loose all your data there? Probably yes if all important pictures are on flick and you keep other important famility documents in the cloud say Google drive or Microsoft OneDrive.
If you keep all important data locally on that PC SSD only is a no go for me and you need fault tollerant HD configuration  :)
« Reply #29 on: 06 November 2015, 11:32:54 am »
DAMIT just been told that they are out of the 8100s but have the 8000 with 2core duo E8400 and not the i3
here is a side by side spek http://www.cpu-world.com/Compare_CPUs/Intel_CM80616003060AE,Intel_EU80570PJ0806M/
the only ovious thing to me is it has 2 threads and the i3 has 4
« Reply #30 on: 06 November 2015, 11:46:55 am »
Sounds like you need a DeLorean  :lol
joebloggs
« Reply #31 on: 06 November 2015, 12:01:32 pm »
 :rollin :rollin :rollin :rollin
To bloody confusing this computer jargon
Bring back the spectrum...............
« Reply #32 on: 06 November 2015, 12:11:18 pm »
Quote
Come on then name and shame so I can avoid
BBROWN1664
« Reply #33 on: 06 November 2015, 12:25:01 pm »
Regarding the CPU, the E8400 benchmarks at  2178 and the i3-540 @ 2708 so the E8400 will be about 20% slower.
NorthWestern
« Reply #34 on: 06 November 2015, 12:41:20 pm »
I wouldn't bother with an SSD to be honest.  We build AAA video games for PS4/XB1/PC etc and our PC's are pretty cutting edge but we don't bother with SSD drives due to reliability and they just don't offer any real performance other than load times but HDD load times are hardly a problem especially for a home machine.
If your not doing very large file edits and/or playing the latest games then pretty much anything will do.  I have an old laptop I occasionally use at home and that can run Photoshop CS6 with 4k images just fine.  I think its an 2.0ghz intel duo with 2 gig ram and the intel on board gfx so waaay inferiour to your current machine.  Win 10 is also much easier on hardware so if your moving to that it will give you a minor boost.
Your current PC spec looks fine for what you say you want to use it for, maybe it just needs a good cleanup, maybe a new gfx card and hdd, fresh install of windows etc  Even modern games don't tax the CPU much anymore its all on the GFX card really - most photo editing software use the gfx card nowadays.  We occasionally get a batch of different spec PC's from dell etc and without question the biggest performance factor is GFX card (for games)  CPU makes little difference and anything with over 8G+ is more or less the same be that 8GB or 16GB.
« Reply #35 on: 06 November 2015, 12:45:16 pm »
Thanks for that
Even I am starting to loose the will to live -----------its turning into a noggy "what bike shall I get"
the 8000 is coming in at £40-£50 cheaper
Now started to look at Dell OptiPlex 790 Small Form Factor i3 3.3GHz 8gb ram anyone have any view on that machine
« Reply #36 on: 06 November 2015, 12:58:32 pm »
Your current PC spec looks fine for what you say you want to use it for, maybe it just needs a good cleanup, maybe a new gfx card and hdd, fresh install of windows etc    CPU makes little difference and anything with over 8G+ is more or less the same be that 8GB or 16GB.
So it sounds like I should steer clear of SSD although the pc never has much on it to lose as it was only 40GB hd so never kept much on it and always saved to DVD any photos.
So a SSD will just make start up quicker --- I thought it made everything quicker.
Also just to recap the current pc is
10 year old + HP D530
P4 2.4GHz
3gb ddr pc2700 166MHz
40gb HD
onboard graphics
 xp pro (not sure how much ram is available)
Thats the family pc for general --- not a lot, but find things like the google maps painfully slow and it randomly restarts -- which of course is my fault cause its old and its broken and Im too tight to buy another one :uhuh
(only one of those statements is correct)
NorthWestern
« Reply #37 on: 06 November 2015, 01:04:30 pm »
The ssd has vastly increased read/write performance over a hdd. It will make some things quick but only if it is involving disk access which won't be happening most of the time. Once you load your photo etc it's loaded into ram so the ssd offers nothing performance wise beyond that. Also loading times isn't bad with hdd so if you half the load time you've saved a second
« Reply #38 on: 06 November 2015, 01:06:18 pm »
So I shouldnt get too eat up about the differences between i.3 3.06GHz and a core 2 duo 3.0GHZ both with 8gb ram then and not bother with a SSD
Also being offered it with a NV 290 graphics card for an extra £10
NorthWestern
« Reply #39 on: 06 November 2015, 01:14:32 pm »
There will be a difference, but you may never notice in real world terms. Benchmark results can be misleading, you may not see a difference between two cpu even if one has 30% better. It's not really 30% better.
If your buying new they are all pretty matched in the price brackets. One bundle might give better speakers, the other better gfx.  You won't really go wrong
NorthWestern
« Reply #40 on: 06 November 2015, 01:26:06 pm »
One thing to note is that sometimes particularly with large PC builders like HP is that they can use special versions of motherboards.  We have got them where the MoBo is, for example an ASUS model, on spec it might have 2 PCI slots and 8 DIMM slots but because DELL or whoever buy so many to build the machines they specify slightly different specs, so when we open them up if the PC only sells with 2 DIMM cards the rest have no sockets soldered onto the motherboard, and maybe the PCI Ex slot is missing.  The holes will be there for the plastic socket but they obviously let the manufacturer not to fit it to save cost and therefore you can't actually upgrade as you might have thought.
« Reply #41 on: 06 November 2015, 02:01:15 pm »
The suppliers website says it has these
 Expansion Slots    2 x PCI-E x 1 slots, 1 x PCI-E x 16 slot, 1 x PCI slot
BBROWN1664
« Reply #42 on: 06 November 2015, 02:19:42 pm »
For HP kit, the spec is accurate. Customers (corporate) buy these things 100's at a time and need them to be identical even when they order some a few months later.
For Dell kit, they have got better. In years gone by, I could open 10 boxes with sequential serial numbers and find two or more different configurations due to their production models. This has changed now though.
Lenovo are as good as HP.
Personally, I would stick with HP or Lenovo if I was buying a ready built PC.
« Reply #43 on: 06 November 2015, 02:24:59 pm »
Foc it I give in, ive just brought this instead ---------
NorthWestern
« Reply #44 on: 06 November 2015, 02:46:49 pm »
Now then, that looks like a pine frame. You really need mahogany with stainless rails,
« Reply #45 on: 06 November 2015, 02:49:21 pm »
 :rollin
BBROWN1664
« Reply #46 on: 06 November 2015, 02:49:29 pm »
Careful there Fazersharp, excessive pressure on them things ends in tears.
« Reply #47 on: 06 November 2015, 02:59:18 pm »
I need to go for a ride and blast all this all shit out of my head ---------------------- oh wait a min its raining fooooooooooooooooooooooC
« Reply #48 on: 06 November 2015, 03:29:30 pm »
 :thumbup THANK YOU EVERYONE WHO HAS HELPED ME
I have an announcement to make    :guitar
I have made a purchase
[/b]HP 8000 elite - Processor: Core 2 Duo 3GHz
 - Memory: 8GB
 - Hard Disk Drive: 400GB
 - Optical Disk Drive: DVD-RW
 - Operating System: Windows 7 Professional (64 bit)
 - Graphics Card: NVS290 with DVI cable
£127 delivered 12 mths RTB
BBROWN1664
« Reply #49 on: 06 November 2015, 03:34:45 pm »
:thumbup
For that price you cant really go wrong.
