Date: 22-04-26  Time: 10:19 am
Author Topic: Problem with the fz1  (Read 1923 times)
brooker81
« on: 13 October 2015, 07:53:44 am »
Stuttering at low rpms like a 2 stroke when higher revs are reached seems to run like normal ? any idea's  :'(
DekF
Re: Problem with the fz1
« Reply #1 on: 13 October 2015, 09:10:58 am »
Symptomatic of a coil-on-plug failing.
Check for corrosion inside the plug caps but especially the far left cylinder ( as sat on the bike).
If it looks clean, use a temperature probe at startup on the exhaust pipes to identify which cylinder is not firing properly. Then swap the cop to another cylinder to see if the stutter follows it.
I replaced the cops & plugs a year before I sold it to you but it’s luck of the draw how long they last.
However, with the limited info you've given it could be one of half a dozen different things but above is the most obvious & easiest to check.
brooker81
« Reply #2 on: 13 October 2015, 09:14:21 am »
Thanks Dek. I think it is a coil found a video on youtube sounds exactly the same. feel a little winter project coming on.
brooker81
« Reply #3 on: 13 October 2015, 09:55:09 am »
would you use genuine yam or non genuine garage are saying use genuine.
DekF
« Reply #4 on: 13 October 2015, 10:41:06 am »
Those coils were originally on a 2010 R1. Very low miles apparently.
£80 the set of 4.
I still have the original 4 which I assume only one of which is faulty. :-)
brooker81
« Reply #5 on: 13 October 2015, 11:04:44 am »
can i give you  a buzz dek? Pm me pal.
