Date: 22-04-26  Time: 04:24 am
Author Topic: To Drill Or Not To Drill?  (Read 5438 times)
MrGimly
« on: 02 October 2015, 02:30:05 pm »
Hi just bought a new Yoshimura tri-oval end can,fitting instructions are simple as per usual but at the bottom it says to drill 4 7/8" holes in the airbox lid?
Don,t like the idea of drilling holes in the top of the airbox but it says to do it so should I?
bristol banger
Re: To Drill Or Not To Drill?
« Reply #1 on: 02 October 2015, 03:40:51 pm »
I wouldn't, but if you are planning on doing it get yourself a spare lid that way if it don't work out your not up shit creak. If it turns out to be the best thing since sliced bread you can always sell it on.
stevierst
« Reply #2 on: 02 October 2015, 05:18:52 pm »
Someone drilled my lads airbox on his bandit 400 and it ran like a bag of nails (it was a shitter anyway).
I just put a couple of layers of gaffer tape over the holes and it ran better. That gaffer tape stayed on there for the two years he was on his restricted licence.
So if it all goes wrong, gaffer tape!
esetest
« Reply #3 on: 02 October 2015, 07:42:47 pm »
You could always plug the holes with blind grommets 25 mms should fit .
slimwilly
« Reply #4 on: 02 October 2015, 07:45:50 pm »
remember ,,most mods are for outright revs = power,,, but if you aint nailing it and want midrange intact be careful,,keep it medium.
Hedgetrimmer
« Reply #5 on: 02 October 2015, 08:14:09 pm »
Interesting. I always had the idea that with just a can swap, you don't need to do owt else, and that you balanced airbox mods with carb jetting changes and the like. Got a tri-oval on mine (Delkevic) though, and I swear it throws the carbs out of balance. Don't know how that could be, but I'm ever more suspicious about it. The Scorpion oval can I had on the last one went on before Ivanising (so no carb or airbox mods to start with) and ran just fine.
Try it without drilling first, see how it runs.
MrGimly
« Reply #6 on: 02 October 2015, 08:50:44 pm »
Decided not to drill the airbox will wait and see how it goes  :)
esetest
« Reply #7 on: 02 October 2015, 09:01:34 pm »
When I installed the K&N air filter it deffo felt faster , when I swapped the standard exhaust for a big bore stubby with baffle it felt slower and popped on the overrun , when Mike did the full Monty ivans on it , it felt quicker and smoother though doesn't pop any more but sounds fantastic above 7k rpm.
bobdog
« Reply #8 on: 03 October 2015, 09:11:20 am »
i have one of those, cut 5 inch off it it looks much better :)
bobdog
« Reply #9 on: 03 October 2015, 09:13:54 am »
i havent drilled the air box but the bike is ivanised runs better with the cut down yoshi than the akra i had on before.
MrGimly
« Reply #10 on: 15 October 2015, 09:49:42 pm »
Hi got a little too inquisitive about the holes in the airbox and drilled them,oh dear!!
Seem to have lost a lot of midrange grunt at the benifit of top end revving which I dont like  :'( think I,m gonna get a new airbox lid  :rolleyes .
Ps Bobdog how did you shorten the yoshi?
NorthWestern
« Reply #11 on: 15 October 2015, 10:11:10 pm »
Nice bit of duck tape will be fine to close the holes.
bobdog
« Reply #12 on: 15 October 2015, 10:58:33 pm »
just drill the rivetts out on the link pipe end, i cut 5 inch off redriled and riveted it back on  :)
