Date: 14-05-26  Time: 15:13 pm
Author Topic: Engine mounts 99 FZS  (Read 8356 times)
Notch000
« on: 08 September 2015, 01:48:43 pm »
Hi,
I had a off a while ago, the bike went up and landed on left side broke stator, stator cover and cracked fairing etc, the bike is back up and running fine now but just noticed tha the engine mounts have taken a kicking. Thre was a crash bug in place that looks to have just folded over with the landing. but ive only noticed that half the rear engine mount has seared off and one side of the front subframe mount point is broke. so im not sure what my option are ???
How bad does it look, engine is sitting about 5-10degrees up on clutch side. Im not riding it on the road at the moment.
Im thinking i could replace the front subframe, jackup engine and reseat & have a bit welded onto the rear ?? would i have to strip back engine exhaust etc to do this ????
Or worst case frame is bent and bike will need to be reframed and registeded
Re: Engine mounts 99 FZS
« Reply #1 on: 08 September 2015, 03:20:27 pm »
Sorry I am no help but just to say the damage is a prime example of why not to use crash bungs on our fzs 600s. I think some new bikes have special bung positions designed to take a bung but ours dont.
Again sorry I was no help and I don't mean to rub it in, its just there was a debate on here not long ago about bungs vs bars
joebloggs
« Reply #2 on: 08 September 2015, 03:29:13 pm »
http://www.ebay.co.uk/itm/YAMAHA-FZS600-FZS-600-FAZER-FRAME-V5-REGISTRATION-DOCUMENT-LOG-BOOK-FWLB-/361360691323?hash=item5422c6907b
Considering you'll need a specialist in to straighten your frame, or at least check it after you have, I'd say buying a frame with V5 would be the cheaper and safest option. As for registering, I'd be inclined to build it up and just send the V5 off for a change of engine numbers and colour if required. My brother has been riding around on a RD80LC with an FJ1200 engine stuffed in it for years and DVLA have no clue as to the fact that it wouldn't fit (custom frame)
Not looking like crash bungs are the way to go......
Notch000
« Reply #3 on: 08 September 2015, 03:44:40 pm »
 I think the crash bungs did absoluetly nohting but bent over, the mounting between the crash bung and the subframe still looks straight and the engine took the brunt of the hit and thats why its knocked out of position
thoughts ???
joebloggs
« Reply #4 on: 08 September 2015, 04:01:32 pm »
Ah so the front mount bolt sheared off and the rear engine casing failed. Looks strange as there doesnt appear to be any damage on the outer engine case, only to the crashbung
Drop the engine, clean up the casing, refit it, and see if it all lines up with all the unbroken mounts before spending any dollars.
« Reply #5 on: 08 September 2015, 04:26:41 pm »
You say you broke the stator cover, which means the engine took the brunt after the crash bung bent. The engine mounts are not designed to take a bang and would be the weakest point.
It is possible that the frame is still intact, but before you go removing the engine, unbolt the exhaust pipe at the joint and the passenger foot peg and remove it, remove the down pipe mount to the frame by the right rider footrest, remove the front engine mounting bolt on the left side which is out of position, loosen all the rest of the engine mounting bolts and see if the engine moves back into place. If it does then you can decide to remove the engine and weld the mounts. Get some to help check the frame for is still straight by using the old method of to long straight poles providing the forks are straight.
Notch000
« Reply #6 on: 08 September 2015, 04:46:16 pm »
That was my first though, will try this first, how many mounting points are there ???
Notch000
« Reply #7 on: 08 September 2015, 04:49:09 pm »
I have replace the stator cover where it landed, casing was toast and had some deep scrapes through it pointing up towards the seat which is the direction the engine has repositioned itself, there was also damage to topbox, fairing and bar end weight took a punch too
Bike landed on my leg !!! any one want to see the X-Rays ??????
Paulfzs
« Reply #8 on: 08 September 2015, 04:49:34 pm »
1 at the back and 2 at the front
the front ones are an utter pain to line up
yes show x-rays
Notch000
« Reply #9 on: 08 September 2015, 04:50:55 pm »
yes show x-rays
I assume be back one is the one that's sheared here ???? its really hard to even see
« Reply #10 on: 08 September 2015, 06:23:04 pm »
Nice to see you saved the bike from even more damage with your leg :eek
A true bike lover  :lol
Yeah! Where are the x-rays?   :useless
joebloggs
« Reply #11 on: 08 September 2015, 06:55:17 pm »
yes show x-rays
Leave um all loose and podgy bar simplifies the job
Bretty
« Reply #12 on: 08 September 2015, 07:32:20 pm »
yes show x-rays
Mountings?!
2 solid through holes at the back (top and bottom) and a pair at the front.
« Reply #13 on: 08 September 2015, 09:05:41 pm »
Mountings?!
 :agree pair at the front attached to the engine bracket. There is a small bracket at the back upper right
joebloggs
« Reply #14 on: 08 September 2015, 10:03:07 pm »
I recon a couple of tubes of liquid metal and a 6" nail (bent over) and it'll be as good as new!
joebloggs
« Reply #15 on: 08 September 2015, 10:04:39 pm »
Oh, and red box tape, every machine in our company is covered in the stuff and they keep running.................
Notch000
« Reply #16 on: 09 September 2015, 03:06:45 pm »
 :rollin Not the best picture but this was about 2 week post opp, i has a compound fracture fibia & tibia, and had compartment symdrome after the initial opp that needed emergency treatment (nice scars, chicks love scars). So overal I had 2 operations, 10 days in hospital, 3 month non-weigh bering, around 5 months on crutchs & all in all probably took 12-18 month to make a full recover and it pretty good now, I might have better picture later.
Accidnet was on friday 13th /sep / 2013  you coudnet make it up !!
The surgeons said i was extremly lucky not to loose it and the first setting operation did the trick of an inital planned 1-3 follows, second surgery was just to close up open fasiamoity (compartment pressure relief)
Be careful out there
Notch000
« Reply #17 on: 09 September 2015, 03:08:50 pm »
repost
joebloggs
« Reply #18 on: 09 September 2015, 03:23:20 pm »
Ouch......OK now?
Notch000
« Reply #19 on: 09 September 2015, 04:25:33 pm »
ya fine, i cant run, kneel down & set of most airport metal detectors with it but ok considering
« Reply #20 on: 09 September 2015, 06:09:15 pm »
Ouch! indeed, lucky lad, lots of limbs lost due to compartmental syndrome not being diagnosed in time. :'(
Came close myself over the same thing, still can't run, but can do everything else. Takes time, a lot of time :)
Bretty
« Reply #21 on: 10 September 2015, 12:36:24 pm »
I think I am being stupid!
There are 4 bolts that go through the engine. 2 at the front side by side and 2 at the back. Long ones, one above the other.
Are you saying there is only one mount at the back? Maybe it is because mine is 2000. I had the engine out again last night and refitted it.
I have some spare engine cases sat outside if any one is interested?
Notch000
« Reply #22 on: 10 September 2015, 03:27:21 pm »
i never notived te upper back one, hopefully its not smashed too !! is it hard to access ?
« Reply #23 on: 10 September 2015, 07:05:54 pm »
Two long ones at the back top and bottom, two short ones at the front left and right.
Probably bent the frame mountings at the rear.
Bretty
« Reply #24 on: 11 September 2015, 10:14:15 am »
You can see the bolt heads if you look.. here and here.. (although not very well on my photo)
