Date: 26-04-26  Time: 01:01 am
Author Topic: Flashing ABS light  (Read 2895 times)
Stewie
Flashing ABS light
« on: 05 July 2015, 12:41:39 pm »
When I was riding yesterday the ABS light started flashing at me.
I pulled over turned it off and back on again and it was ok for a while but then it started again and reset again.
I was not riding stupid, when it happened, or doing really heavy breaking and the ABS did function with the light flashing, I tried to lock up the rear and I could feel it pulsing.
The flash was on for about a second and then off for about a second as well if this helps.
I have checked the manuals, service and owners, and there is nothing I can see.
I have also checked t'Internet and there is nothing really about my issue.
pilninggas
Stewie
Re: Flashing ABS light
« Reply #2 on: 05 July 2015, 06:49:58 pm »
Worth a read:
http://www.fjrowners.com/forums/9-fjr-technical/7702-abs-light-flashing.html
Thanks for that.
With other trolling I have a list of items to check
ABS sensors
brake pedal switchs
fluid levels
Bearings and axles
I might have to check my new lights and flashers also.
Stewie
« Reply #3 on: 06 July 2015, 08:28:39 pm »
I found the problem after not too much searching.
Brake light had blown so there was low load on the circuit which set the warning light off.
