Date: 07-05-26  Time: 09:12 am
Author Topic: Is this normal?  (Read 15410 times)
7omly
Is this normal?
« on: 30 June 2015, 12:25:22 am »
I'm a bit perplexed. I pulled up next to another Fazer today and noticed it it had a different speedo to mine. Mine has a 260mph speedo. The other Fazer had a 260kph/160mph. Mine has no kph scale. Is this normal?
Paulfzs
Re: Is this normal?
« Reply #1 on: 30 June 2015, 02:24:21 am »
notice your "mph" sticker that is covering a kmh print.
it will have a speedo healer built in to take it to mph.
clayt74
Re: Is this normal?
« Reply #2 on: 30 June 2015, 07:59:10 am »
Or if it doesn't have a healer fitted, you have been riding very slowly lol.
BBROWN1664
Re: Is this normal?
« Reply #3 on: 30 June 2015, 08:11:23 am »
:agree
That is the speedo off of a European bike. Your bike may be a parallel import rather than a genuine UK bike or the speedo may have been changed for a euro one.
Re: Is this normal?
« Reply #4 on: 30 June 2015, 09:43:58 am »
Yep definitely a MPH sicker over the KPH
celticdog
Re: Is this normal?
« Reply #5 on: 30 June 2015, 09:45:49 am »
Hi 7omly,
in top gear at around 5000 revs have a look at what the speedo reads . . .
Is it 60 or 100? This will tell you if your reading Mph (60) or Kph (100)  :rollin
Anyway, 260mph! that's the top end of this Porsche 9FF, even if it is blue  :lol
Paulfzs
Re: Is this normal?
« Reply #6 on: 30 June 2015, 12:29:42 pm »
Hi 7omly,
I know some people make a lot of stuff up on here to look cool but come on man.. a blue car doing 260mph... only a black car can go that fast.
7omly
Re: Is this normal?
« Reply #7 on: 01 July 2015, 01:11:03 am »
Around 60mph at 5000rpm. The good news is I can simply replace it with a genuine UK speedo? Anyone got one going cheap?
Paulfzs
BBROWN1664
Re: Is this normal?
« Reply #9 on: 01 July 2015, 08:42:14 am »
7omly - There will be a box of tricks somewhere between the sensor and the speedo to make it read 60 instead of 100. You will have to remove that if you fit a UK speedo.
7omly
Re: Is this normal?
« Reply #10 on: 02 July 2015, 12:17:18 am »
Thanks BBROWN1664, I thought as much. I'm hoping it's just behind the speedo. To get a replacement with a time clock isn't easy as most are the earlier 1998-99 ones. It's still a fantastic bike and has rekindled my love of riding. The divvy was more or less for commuting but the Fazer is for everything because it's just fun to ride. I even find myself riding when it's rainy instead of using the car. :)
Paulfzs
Re: Is this normal?
« Reply #11 on: 02 July 2015, 01:56:37 am »
buy the number sheet thing that i posted above for £20. job done.
BBROWN1664
Re: Is this normal?
« Reply #12 on: 02 July 2015, 08:53:48 am »
7Omly - The connectors are different on the later speedos. it wont be a straight plug in job.
7omly
Re: Is this normal?
« Reply #13 on: 02 July 2015, 07:48:30 pm »
My bike is a 2000 FZS600S with the time clock on it.  I thought of buying the dial  but was too keen on taking off the speedo needle. If I buy that dial will I have to remove the speedo healer. At 70 my needle is only one third of the way round the dial but on UK bikes 70mph is almost half way round.
Paulfzs
Re: Is this normal?
« Reply #14 on: 02 July 2015, 08:23:17 pm »
the healer is just a box with a plug on it.
get a decent set of pliers on the needle itll be fine
7omly
Re: Is this normal?
« Reply #15 on: 02 July 2015, 08:30:28 pm »
Thanks for the advice. I'm now unsure if the clocks are even off the right bike. Mine have odometer, trip one, trip two and time clock respectively when you press the top button. However I've seen what I assume are later boxeye clocks with a separate LCD display at the bottom of the rev counter. The more I look into it the more confused I am.
Paulfzs
Re: Is this normal?
« Reply #16 on: 02 July 2015, 09:11:21 pm »
post a picture of your whole clocks.
7omly
Re: Is this normal?
« Reply #17 on: 03 July 2015, 02:12:27 am »
Here are the clocks on the bike.
Decoke Dave
Re: Is this normal?
« Reply #18 on: 05 July 2015, 04:47:41 pm »
My bike is exactly the same.  Please correct me if I am wrong, but if you fit a new U. K. speedo face obviously the needle will then not read correctly, you will have to remove the electrical corrector box.  But the bike will then record the mileage in kilometres as it is a genuine European speedo you have stuck the new face onto!  I think?
BBROWN1664
Re: Is this normal?
« Reply #19 on: 05 July 2015, 06:28:31 pm »
Decoke
If you convert the speedo (as 7Omly's has been done) the odometer starts to increase in miles instead of km's from the point of the conversion.
Decoke Dave
Re: Is this normal?
« Reply #20 on: 07 July 2015, 04:55:16 am »
Decoke
Sorry I wasn't very clear on what I was saying, I meant if he tries to change it to be like a U.K. bike by fitting a replacement U.K. style  dial face and removing the corrector, the speedo will be o.k. but it will revert back to recording the distance in kilometres.  I think! Please correct me if i am wrong.
BBROWN1664
Re: Is this normal?
« Reply #21 on: 07 July 2015, 08:43:32 am »
yes. That's right.
Dismantling the speedo case will often cause more problems than it solves too.
7omly
Re: Is this normal?
« Reply #22 on: 09 July 2015, 01:16:29 pm »
The nightmare continues. I purchased a low mileage (15,500 miles) and they look mint. I followed the advice of foccers and removed the speedo healer. I fitted the replacement clocks and the fun began. As soon as I switched the ignition on the speedo needle went to 28mph. I took the bike for a ride and ridethe speedo responds oddly. I reckon I was doing around 45 but the speedo was showing around 75mph. My bike appears to have an electronic speedo pick up on the left fork leg. Are these Kmh or Mph specific. I beginning to despair. The bike runs perfect in all other respects. Whilst I was removing the speedo healer from the junction box under the tank I found this item with a green wire going into one side and a black/red one coming out of the other but not connected to anything. Any help would be grateful because I now have the better half nagging me about buying a dog, not the canine variety but the bike. Women don't understand that at 15 year old it just might need some maintenance.
7omly
Re: Is this normal?
« Reply #23 on: 09 July 2015, 01:19:29 pm »
Speedo running at 28 mph at idle.  :'(
7omly
Re: Is this normal?
« Reply #24 on: 09 July 2015, 01:22:23 pm »
Removing this didn't sort it as I hoped it would.  :'(
