Date: 25-04-26  Time: 09:52 am
Author Topic: White Tank Behid Rear Shock, What is it?  (Read 3453 times)
sox22ufo
« on: 25 June 2015, 06:33:09 pm »
Hi Guys theres a white tank, looks like a water holder behind the rear shock, what is it, as its empty, should there be water in it :eek :eek :eek
mickvp
  • Global Moderator
Re: White Tank Behid Rear Shock, What is it?
« Reply #1 on: 25 June 2015, 06:34:49 pm »
It's the expansion tank for the radiator. There's a level on it at the side I'm sure
« Reply #2 on: 25 June 2015, 07:03:10 pm »
Two lines on the rear face, upper and lower limits, top it up to the high level using a anti freeze mix    ;)
sox22ufo
« Reply #3 on: 25 June 2015, 07:22:15 pm »
Its empty so I'll top it up to the highest level,
cheers guys
AyJay
« Reply #4 on: 25 June 2015, 09:01:24 pm »
That's an interesting spot. I've only ever filled the system using the radiator cap under the fairing infill, but the manual says fill the bottle. Can't say it's ever done it any harm though, but I do run the engine with the cap off to let the system bleed for a while.
PieEater
« Reply #5 on: 26 June 2015, 09:38:11 am »
I'd also take off the radiator cap and check the coolant level in the system.
brooker81
« Reply #6 on: 26 June 2015, 10:28:29 am »
lol. at this
coppi
« Reply #7 on: 30 June 2015, 04:12:41 pm »
One little addition to all the other replies:
Use distilled water only with your antifreeze mix. Keep an eye on your expansion tank, it should not be getting empty - if it does it again then there is a problem.  Possibly a leak or, the cooling system is running too hot and boiling, whereby coolant will exit via overflow pipe from e/tank.
FazerFazersson
« Reply #8 on: 30 June 2015, 09:31:16 pm »
And don't forget to check while on the centre stand as a full tank will appear empty while on sidestand.
