Date: 15-03-26  Time: 02:50 am
Author Topic: Is the 2008/9 r6 shock mod for early fazer 6 as well?  (Read 3174 times)
Tubz1983
« on: 21 June 2015, 11:49:03 am »
Seen a few posts on here about replacing the standard rear shock with a 2008/9 r6 unit, but I'm unsure if it only applies to the fazer 1000 ? Thanks
Boris
Re: Is the 2008/9 r6 shock mod for early fazer 6 as well?
« Reply #1 on: 24 June 2015, 09:57:52 pm »
Yes it does. As the end of the FZ6 shock that connects to the swingarm is a different design to those R6 aftermarket ones used on Fazer Gen 1's.
risticuss
« Reply #2 on: 23 July 2015, 10:36:49 pm »
Now don't quote me on this,  but the 98-01 r6 shock has a similar mounting configuration so 'might' fit.
Quite cheap on eBay too so could be worth a punt, or a bit of research into the sizes/measurements.
kebab19
« Reply #3 on: 24 July 2015, 08:32:17 am »
I believe the FZ6 has no shock linkage mechanism - it's attached directly to the swingarm?
If so, then at the very least the spring would need to be much heavier - twice the rate of something like an R1.  Furthermore, the internal valving will also be off.
You may however be able to get away with just a spring change.
