Date: 07-05-26  Time: 01:17 am
Author Topic: What have you done to your FZS600 bike today  (Read 314994 times)
Carter
Re: What have you done to your FZS600 bike today
« Reply #275 on: 19 June 2016, 05:42:34 pm »
Thanks , I tried to put a pic up using the way but it didn't work, will put just the link up later and see how it goes.
Carter
« Reply #276 on: 19 June 2016, 10:52:43 pm »
http://s1278.photobucket.com/user/ElGarro2/media/Fazer/20160619_000046_zps3jqltpxk.jpg.html?sort=3&o=0
nearly finished. Think it's a motad system. I used to make stainless exhausts years back and where possible, stuck the seam of the tube inside the bends where it was least likely to be seen. Still, things are usually made to a price these days.
« Reply #277 on: 20 June 2016, 12:20:50 am »
I'm not sure how to post pics on here sorry.
when replying or adding a new post, below the box you are typing in is  Additional Options
Click on Additional Options
Click Browse and it will open a window to your local drive.
Select the file and click Open
If you want to add more then click More Attachments  and repeat.
when finished click Post. It will take a little longer to post as it is uploading the file to the FOC-U-UK server  :thumbup
You can add a max of four using this method.
« Reply #278 on: 20 June 2016, 06:28:54 am »
Did the Bike Copper make any reference as to  how some of the numbers fell off your reg plate  :lol
:lol
When did the cops start advertising fast food outlets?
 :rollin :rollin :rollin
CHiPs
« Reply #279 on: 20 June 2016, 08:52:04 am »
Nice Work, not sure about the fairing but rest of the bike looks cool. Just think the fairing cheapens the rest of a great looking job.
If I send you my pipes will you polish them?  :lol
Carter
« Reply #280 on: 20 June 2016, 05:33:29 pm »
Thanks for the help with pics Unfazed, I'm not too clued up on this interWeb stuff. I'm undecided about the fairing too, would've had a pair of cibie lamps on a bracket from the headstock if I'd have built it myself, love the bug eye look. Don't reckon the little halogens will last long on the roads around here, the fat bars are going too, it's got double risers so will get a single set and put renthals on as soon as winter comes. Plan to wrinkle paint the engine and polish the side casings and cam caps, can do them on the mops so not as difficult as doing the pipes, that was a real ball ache. I'm going to jib out of offering to do yours :) got the yellow/gold oxide and rust blobs off with birchwood casey rust and blue remover for guns before the polishing, it's probably the same as alloy wheel cleaner but a good bit stronger.
Val
« Reply #281 on: 22 June 2016, 05:59:49 pm »
Changed today my front foot rests with vario CNC adjustable 23mm ones from MFW  :) the original ones has a rivet so this needs to drilled out to get the new ones in.
TOADY
« Reply #282 on: 22 June 2016, 07:49:23 pm »
Fitted rentals and rental grips. Ordered an akrapovic copyfrom Hong Kong. Will post pics and a review when I get it
xthib1
« Reply #283 on: 30 June 2016, 06:11:51 pm »
Today I changed my Fuel filter
That wasn't a lot easier than I thought!
bigsteve
« Reply #284 on: 30 June 2016, 09:26:43 pm »
     rebuilt forks after a oops moment  :'(    :'(
 make sure u remove disc lock before pulling away and shot disc lock up the street
   bet Thatcham don't test that way of removing them
paulchucky
« Reply #285 on: 03 July 2016, 06:19:34 pm »
went for MOT yesterday  passed with flying colours  :) :) :)
tester was impressed with condition etc  :D
Albert Herring
« Reply #286 on: 05 July 2016, 02:31:29 pm »
Started making some horrible graunching noises in the latter stages of a quick 500 mile bimble over the weekend, so I gritted my teeth and looked to see if the front sprocket might need changing.
I think that's a yes. Whether that (and the small rockery that was embedded in the oily gunge under the sprocket cover) was causing the bumping and grinding remains to be seen, though.
At least I now know where to look for dropped battery terminal screws, anyway. And the bike is half a kilo lighter. And I get to change that dodgy nut (I think it's the thin one, at any rate).
xthib1
« Reply #287 on: 06 July 2016, 06:03:13 pm »
Today I changed my brake fluids  :)
Brettholmes89
« Reply #288 on: 07 July 2016, 08:49:24 pm »
Today I made the footrest brackets I saw on here.
I made an alloy gear change rod.
Only small bits.
« Reply #289 on: 07 July 2016, 09:07:18 pm »
You two are putting me to shame with all of your making stuff from stuff skills, brake airlock, foot rest adjuster-- so I thought I would have a go at making something myself
sinto
« Reply #290 on: 13 July 2016, 04:27:10 am »
Sorted my digigear en route to work :thumbup
Replaced my rear brake for a bluespot after work :thumbup
Couldn't get it to bleed properly :thumbdown
But after a beer and a chat on the 1000 thread I kept going and success :thumbup
Next job on my list is to replace front pads while I still try to figure out how to change the clocks, it's giving me headaches, I thought it was a straight swap :(
stinch182
« Reply #291 on: 14 July 2016, 12:49:03 pm »
Fitted a new road pilot4 ready for mot on Monday .... better clean it before wheel is fitted again ...
Sent from my D6603 using Tapatalk
taylor
« Reply #292 on: 19 July 2016, 07:13:10 pm »
new mot straight through for 4 years running.
« Reply #293 on: 23 July 2016, 01:51:02 pm »
Just nabbed myself a complete bargain. Well happy.  :D
markeb
« Reply #294 on: 23 July 2016, 08:57:55 pm »
cleaned, rode, cursed her, then made up. lol.
misterjayb1
« Reply #295 on: 25 July 2016, 04:03:47 pm »
Mainly resprayed the fin area on the cylinder head of the foxeye.. If you shut one eye and stand on one leg, the finish is great  :lol
sgpwwg
« Reply #296 on: 25 July 2016, 10:45:51 pm »
Had another great track day at Bedford Autodrome. Changed the front sprocket to 13 tooth for greater punch out of the corners. Videos being uploaded to YouTube tonight if anyones interested. Still revs into the red-line, fastest top speed 134 on the back straight not bad for 86,000+ miles. Added a few pics from the day.
gicut58
« Reply #297 on: 26 July 2016, 09:19:44 pm »
Yesterday rather than today, rode in to work and met up with big brother!
After, took up to Deefer's for a complete overhaul (fluids, plugs, filters, brakes, brake lines, calipers & pistons and a carb balance) over the next few days
Hope to end up with a bike that drives the way it looks  :)
stinch182
« Reply #298 on: 31 July 2016, 09:08:21 am »
I fitted my new fzs1000 rear shock .
Also realised the linkage was fubar ....
misterjayb1
« Reply #299 on: 01 August 2016, 04:50:18 pm »
Mainly painted n lacquered the scabby fork legs..
