Date: 08-05-26  Time: 08:22 am
Author Topic: USB/Charger Port  (Read 14997 times)
dilboy
Re: USB/Charger Port
« Reply #25 on: 30 May 2015, 12:20:12 pm »
 I bought the fuse and connectors at Maplins,explained the situation and he suggested the 15a fuse.
Regarding the wire not sure there  :)
sinto
« Reply #26 on: 30 May 2015, 01:27:11 pm »
There's your problem, Maplin's have no clue about bike electrics :groan
dilboy
« Reply #27 on: 30 May 2015, 01:54:42 pm »
And neither do I  :wall
dilboy
« Reply #28 on: 30 May 2015, 02:40:46 pm »
Plus I've just fond the earth wire has a break inside it so, got to replace it :'(
I've had a look at the ignition idea, looked in the fuse box, but it scared me so I ran off, could it be explained again in really easy steps.
Dilboy, the not so good electrician  :evil
sinto
« Reply #29 on: 30 May 2015, 03:47:26 pm »
Here it is in really easy steps for you
You'll need to find thefuse box near battery,
Have a circuit tester (or 2 bits of wire with 12v bulb)
Connect one end to NEGATIVE on battery
Switch on ignition
Touch terminals (one at a time) with other wire or terminal of circuit tester
You will see light come on or movement on circuit tester
Switch off ignition
If light goes out, that's where you want to connect your POSITIVE wire from.your USB charger and leave the NEGATIVE on the battery or find an earth nearby.
If you don't get a light coming on or movement on the tester, repeat the above steps till you do.
Simples, job done
« Reply #30 on: 30 May 2015, 10:19:10 pm »
Show the foccer a picture :lol :lol
A picture tells a thousands words :rollin :rollin :rollin
One thing "a 15amp fuse" What the Foc are they charging, the battery in the truck John McGuinness uses for going to races? :lol :lol
sinto
« Reply #31 on: 30 May 2015, 10:32:58 pm »
Who's to show who a picture? And of what exactly?
(this thread could go in a totally different direction now) ;)
« Reply #32 on: 30 May 2015, 10:42:09 pm »
Here's hoping it does :lol
sinto
« Reply #33 on: 30 May 2015, 10:45:37 pm »
:agree
:useless
