Date: 09-05-26  Time: 10:03 am
Author Topic: Bar Mirrors...  (Read 6847 times)
celticdog
Re: Bar Mirrors...
« Reply #25 on: 25 May 2015, 11:40:27 am »
It's a difficult one, the old elbow in mirror problem. I've got the little disc mirrors fitted, not ideal but they give a good view of the road periphery.
anutz
Re: Bar Mirrors...
« Reply #26 on: 25 May 2015, 11:43:28 am »
i ordered a set of those bar end ones off the ebay link - cheap enough for a gamble....and not horiffic looking....depending on your view point
Re: Bar Mirrors...
« Reply #27 on: 25 May 2015, 11:53:51 am »
Those bar end ones looks like you have removed the OEM bar weights -- is that an issue, it would be better if that clamp on the mirrors went around the OEM bar ends without having to remove them to fit the mirrors
anutz
Re: Bar Mirrors...
« Reply #28 on: 25 May 2015, 11:55:26 am »
i think u are correct on inspection.....
Nebuchernezzer
Re: Bar Mirrors...
« Reply #29 on: 26 May 2015, 07:32:51 am »
The ones I got could probably clamp around a bar weight if the weight is the right diameter.
The mirrors come clamped to a piece of aluminium with a bolt through it that you screw to the bars anyways.  Just unclamp them off that and clamp them onto your weights (if they are the right diameter as mentioned before)
I didn't have bar end weights, just caps so i just took them out and screwed in the ebay bar end mirrors.
I've not noticed any bad vibes etc without weights anyways but i don't spend alot of time at one speed (commuting across city mostly)
EDIT: yeah those cheapos off ebay are the same as what i have.
