Date: 07-05-26  Time: 18:31 pm
Author Topic: Snapped Exhaust studs part II  (Read 13483 times)
Jules-C
Re: Snapped Exhaust studs part II
« Reply #25 on: 25 May 2015, 12:46:19 pm »
Yeah look pretty good to me too.  The ring marks just look nothing more than marks were it's been sitting for a while and nothing to worry about.  I think you risk doing more harm than good if you try doing anything more to them
anutz
« Reply #26 on: 25 May 2015, 12:56:21 pm »
yes i think less is more in some cases, especially with this stuff......i need to make sure i am careful when i remove all the old gaskets on the mating surfaces as well.....
« Reply #27 on: 25 May 2015, 08:25:53 pm »
Look good to me.... ;).....did you see the engine running before you bought it ?
anutz
« Reply #28 on: 26 May 2015, 11:49:56 am »
no... :o
but i have assurances in email before i bought it ran etc....so any major issues i should be ok....i hope! :rolleyes
what can go wrong eh!!!!! :lol
anutz
« Reply #29 on: 11 June 2015, 06:50:07 pm »
In the intersts of keeping the landing page from killing internet connections with hundreds of image downloads i will just post updates inline...
So cylinder head been drilled and all exhaust stud holes look good, got a stainless steel set on the way i got for 7£ so will fit them when they arrive...
And....
Ignore the head in the background, one i got off ebay and when it arrived the camshaft caps were snapped so its for the bin....
Head and Cylinder gaskets on the way as well...
anutz
« Reply #30 on: 05 July 2015, 06:14:03 pm »
Anyone tell me what this component is - its the white thing i removed from the recess above, i think it must be oil pressure sensor or something....has a orange rubber O-ring, i cannot see it in the service manual - but am still looking
The left hand hole is where the water pump fits, i have removed that for cleaning....to the top right would be the sprocket....hope that gives you a location
Currently cleaning the engine as you can see
mobile mouse
« Reply #31 on: 05 July 2015, 08:24:55 pm »
It looks like the neutral gear sensor. the orange rubber is an oil seal.
When the gearbox is in neutral then there is a brass pin (this pin rotates when you change gear) under were you removed the white plastic unit which makes contact and is a short to ground i think and the green neutral light on the instrumentation lights.
anutz
« Reply #32 on: 06 July 2015, 08:27:50 am »
thanks for that mobile mouse - indeed that is what it is......
anutz
« Reply #33 on: 06 July 2015, 08:33:23 am »
anyone ever used shot blast on the engine to clean it up....been reading about soda blast as well which leaves a protectvie film on until you paint it...
or am i asking for a world of pain
sinto
« Reply #34 on: 06 July 2015, 10:13:56 am »
Not that I've used shot blast anutz, but I've only seen it done on biggish bits of metal etc, not seen it done on engines.
But I've heard/read somewhere about dipping the engine in some sort of solvent, but check up first as I'm not 100% sure what solvent etc
mobile mouse
« Reply #35 on: 06 July 2015, 08:22:34 pm »
google vapour blast... and select images
I have never seen parts so clean, they can do whole engines.
There may be someone who does it near you..
anutz
« Reply #36 on: 06 July 2015, 08:28:21 pm »
will have a look into that, right now i need to take the head down the engine shop, looking at it there are one or 2 tiny marks on it, want to see what they think, one is near a water jacket channel ( assuming thats what its called ) but its not borken the perimieter of it
anutz
« Reply #37 on: 06 July 2015, 09:01:22 pm »
anutz
« Reply #38 on: 10 July 2015, 09:07:40 pm »
Pistons cleaned up and almost ready to re-assemble, any one recommend a good piston ring compressor they have used?
His Dudeness
« Reply #39 on: 10 July 2015, 10:46:27 pm »
What did you use to clean the carbon off the pistons?
anutz
« Reply #40 on: 10 July 2015, 11:18:07 pm »
this stuff....
http://www.amazon.co.uk/Gunk-6863-1L-Degreaser-Cleaner/dp/B006ZZ4AHS/ref=pd_cp_263_2
worked surprisingly well considering its not corrosive or that harsh, green friendly as well...
His Dudeness
« Reply #41 on: 11 July 2015, 12:18:37 am »
Ok thanks. Is it just a standard degreaser?
anutz
« Reply #42 on: 11 July 2015, 08:41:22 am »
i think so - not sure what other considerations they are about it - i chose it as it was "green" and was sick of using what i would deems as hasrsh cleaners that made your hands sting if you got a tear in a glove etc, this is a little potent but less trouble, also supposed to be eco friendly.....
