Date: 07-05-26  Time: 16:31 pm
Author Topic: vibration  (Read 18644 times)
mickvp
  • Global Moderator
Re: vibration
« Reply #25 on: 15 May 2015, 01:31:15 pm »
If you shoogle that bit does it rattle or move very much. I doubt it is that but I would want to sort that anyway just to be sure
sinto
Re: vibration
« Reply #26 on: 15 May 2015, 01:38:07 pm »
No mickvp, doesn't rattle at all but it is leaking, was just curious if that was anything to do with it.
I'll pm you in a couple of weeks and we can sort something out re the carb balance?
Paulfzs
Re: vibration
« Reply #27 on: 15 May 2015, 07:16:45 pm »
all fzs 600 exhausts are like that.
sinto
Re: vibration
« Reply #28 on: 15 May 2015, 07:38:35 pm »
Surely they shouldn't have a leak before the silencer?? In fact, I don't think exhausts should have a leak anywhere.
anutz
Re: vibration
« Reply #29 on: 15 May 2015, 08:00:11 pm »
so mine is similar but i don't use it - have a different can...
And
sinto
Re: vibration
« Reply #30 on: 15 May 2015, 08:03:52 pm »
Yeah, they're all like that to look at as far as i know, but mine's blown within that gap :(
So I'll get it welded / braised round the whole lot and that should improve the exhaust even if it doesn't resolve the vibration.
mickvp
  • Global Moderator
Re: vibration
« Reply #31 on: 15 May 2015, 08:33:50 pm »
Sure thing Colin, just fire me a PM when you want it and we will arrange a time and place to meet up/do it/whatever :)
sinto
Re: vibration
« Reply #32 on: 15 May 2015, 08:41:00 pm »
Yeah, I'll work on getting the wee things sorted first, don't know if it'll affect the carb balance if the exhaust is blown? But I have contacts who can weld it :)
Ebme Geek
Re: vibration
« Reply #33 on: 18 May 2015, 05:12:22 pm »
From this thread about the condensate drain holes, rusting inner plates etc....., there is a a good picture showing the structure of the silencer
http://foc-u.co.uk/index.php/topic,15938.msg183103.html#msg183103
Yes, your can is on the way out.
The only good news is that if money's tight you can bodge it for a fair time. I used high temp silicone sealant to bung up the gap between the inner and outer bits where the pipe enters the can. It did get through a couple of MOTs that way, but the rattle got too irritating in the end.
The problem is the inner mild steel rusts through down at the bottom (despite the drain holes).
I dismantled mine:
You can see the two inner flanges have rotted through (ignore the slot in the stainless to the left, that's just my clumsy hacksawing). Not shown is the mesh sleeve that the internals are spot-welded to, that's surrounded with mineral wool before being slid into the stainless outer. The mesh gets rusted away at the lower end too so quite a bit of the wool had blown out.
sinto
Re: vibration
« Reply #34 on: 18 May 2015, 08:48:06 pm »
Yeah I read that thread with interest but no way am I cutting my pipe down like that lol but been asking my welder who's able to do something, so just need to get it to him now, should do me for now and stop the onslot of it getting worse quicker, but as i say, don't think this is causing the vibration feeling I'm getting but it won't hurt to fix it and see first before getting the carbs done which I really will be getting done anyhow as don't know when they were last done :(
mickvp
  • Global Moderator
Re: vibration
« Reply #35 on: 18 May 2015, 10:19:44 pm »
Aye, definitely won't do you any harm doing the carbs as you say Colin. It smoothed things out a good bit on my 600, ran a lot better after that.
sinto
Re: vibration
« Reply #36 on: 18 May 2015, 10:37:15 pm »
True Mick, I know for a fact it's been at least 4years as i know the 2 previous owners and they didn't do them, just need to organise a time that suits us and we'll get it done. :)
Doggy
Re: vibration
« Reply #37 on: 01 July 2015, 07:49:42 pm »
Hi Guys
Sorry for the delay in replying.
Rear pegs made no vibration.
Standard exhaust fitted, no difference.
Doggy
Silverlegacy
Re: vibration
« Reply #38 on: 02 July 2015, 03:34:06 pm »
you will have to let me know how the welding goes, as I had my bike serviced the other day and carbs stripped and cleaned and sync'd and mine still has a vibration patch between 5-7k.
The garage said again the bikes running fine but my exhaust blows in the same place as yours, tried using some gun gum to fill the hole as read about on it here earlier in the year, but its not working too well as its just a pain to get it in the gap and make a good seal.
I did get another pipe off ebay but it had the same problem, so maybe its just one of those things with the original exhaust?
Davew
Re: vibration
« Reply #39 on: 13 July 2015, 10:37:11 am »
Silverlegacy-my bike has the same annoying vibes you describe and I've been through absolutely everything to get rid of them with no luck, so if you manage to fix it please let me know!  I can confirm that (in my bike at least)  its not the exhaust, downpipes, fuel tank, fuel tank mounts, pegs as I've ive replaced all of them with no change!  also done several carb balances.
hope you figure out what it is, but it seems like some fazers are made a little better/smoother than others!
Silverlegacy
Re: vibration
« Reply #40 on: 13 July 2015, 11:33:38 am »
My bikes going back to the garage Friday for another carb strip and clean as i had it done two weeks ago and wasnt entirely happy with how he did them so he said he will do them again for free (guilty conscience)
I am going to him to go over all the internals and check needs and jets and everything this time, worst case if anything needs changing then this may resolve the problem.
Hard to tell how things have worn since 1998 when the bike was new, but its only done 36k so hopefully theres still loads of life left in it.
His Dudeness
Re: vibration
« Reply #41 on: 13 July 2015, 12:01:13 pm »
This is all just my opinion but they all seem to vibrate to some extent at around 5k so I don't think that vibration alone is an indication of there being a problem with the bike. If you've got a drop in performance as well then yeah you've got a separate problem but I think that vibration is just a trait of that model Fazer and that it's due to something in the design of the bike rather than an indication of there being a specific problem with the bike. Cleaning carbs isn't going to get rid of that vibration. I'd say if you put a brand new set of carbs straight from the factory into your bike it'd still vibrate at around 5,000RPM so you'll probably have to live with it (or get a different bike). It doesn't bother me at all I just stay above or below 5k and that's it really problem solved :lol
Silverlegacy
Re: vibration
« Reply #42 on: 13 July 2015, 12:12:02 pm »
I really wish i could find another fazer close to me so they could either ride mine or i could ride theres to compare them.
I have heard alot about them being a bit vibey but i thinkmy patch between 5-7k just seems be a bit to much, i am pretty sure the fazer i had about 10 years ago wasnt anything like this and I used to love pushing the engine, where as this one i have now i feel like I have to hold off or try  and stay below 5k.
Maybe its more to do with worn parts than clean carbs.
Hopefully will have more info come weekend/early next week.
