Date: 26-04-26  Time: 07:58 am
Author Topic: seized lower leg adjusters how to fix  (Read 2875 times)
devilsyam
« on: 30 April 2015, 07:50:14 pm »
this is my way works for me there may be other ways
if the adjuster is solid as this welsh won was after a winters riding DONT force it
do as this picture
any bit hose will do fill with penatrating fluid and leave 24 48 hours
then gently see if any movment make sure screwdriver is correct for slot or you will foc it
work back and forward gently if still rock solid leave bit longer and repeat
last resort
the ring around the adjuster is ally gently heat with paint stripper you will no when hot enough as fluid will fizz up whilst hot spray pen fliud and leave to cool
luke
nickodemon
Re: seized lower leg adjusters how to fix
« Reply #1 on: 30 April 2015, 10:56:27 pm »
I had a gen 1 that had seized adjusters and tried soaking in silkopen, also using heat spray and freezing spray. i soaked them for days and even used my blow torch and couldn't get them to budge. I gave up and gave them to a bike shop. They gave them back saying they were freed off, but what they actually did was free off the aluminium housing so everything rotated :(
« Reply #2 on: 30 April 2015, 11:37:50 pm »
I used a similar set up to Luke, but used diesel, worked a treat, but took about a week of heating, cooling, twisting. Bike had spent 2 years out in all weather and in everyday use in all weather around London/M25. Make sure the screwdriver is a good fit and as Luke said do not force it.
devilsyam
« Reply #3 on: 01 May 2015, 05:10:41 pm »
prevention is way easier for thoose all round riders i suggest cover them in vasiline keep the crap out
b1k3rdude
« Reply #4 on: 02 May 2015, 11:14:51 am »
Had the same issue with one of previous thou's a few years ago, I just squirted Fuchs graphite penetrating fluid (sourced from local ktm dealer) into/on them before and after each ride for a 5 days then on Saturday they moved retentively easily with a wide flat blade screwdriver.
+1, don't forget to reapply every wash etc.
