Date: 20-08-26  Time: 00:17 am
Author Topic: Ignition advancer  (Read 20218 times)
Andy FZS
Re: Ignition advancer
« Reply #25 on: 11 April 2015, 09:15:12 pm »
I might have a bit of gasket paper kicking around if it not to delicate a shape. I might have to resist using a ball pein hammer though lol.
Woodzey80
« Reply #26 on: 11 April 2015, 09:25:13 pm »
My gasket ripped when I was changing mine but I just carefully scraped the old gasket off both surfaces & then re assembled with some gasket sealant, did the job fine & cheaper & easier than getting hold of an oem gasket.
Ps well worth doing the mod !
Andy FZS
« Reply #27 on: 11 April 2015, 09:35:39 pm »
Might have a look tomorrow then.
Andy FZS
« Reply #28 on: 13 April 2015, 08:11:45 am »
Anyone bought a new gasket and if from where, I believe the manual states 60Nm to tighten the pickup bolt.
Cheers
Andy
stevierst
« Reply #29 on: 13 April 2015, 12:24:36 pm »
Didn't bother with a new gasket. A bit of silicone sealant does the trick, as it physically doesn't hold any oil in the casing.
Falco9
« Reply #30 on: 14 April 2015, 12:21:01 pm »
For the tiny cost (£14 off fleabay delivered) I bought one and fitted it yesterday. I'd just fitted a new gasket so it came away perfectly and I managed to get the bolt off just with the bike in gear and standing on the back brake whilst using a breaker bar. 10min swap over max. Torqueing it back up wasn't as easy but by using the same technique to tighten the bolt whilst holding the brake on eventually the wrench clicked (It is 60nm or 44ft/lb)
I wasn't expecting much of an improvement as I've never had an issue starting my bike but to be honest it fair leapt off the starter and ticked over very smoothly so........so far so good
F9  :)
fireblake
« Reply #31 on: 15 April 2015, 11:44:35 am »
I think this will be my next mod. I've noticed on my last ride that unless i blip the throttle a bit before pulling away the bike has a slow pick up. It's only a little bit slow but it's at the worst time, when I've got to the front of a queue and the lights change. I know about it so would normally blip it a bit but once in a while i forget to.
Mickey
dickturpin
« Reply #32 on: 19 April 2015, 11:15:16 am »
OK guys....just ordered one....now how likely am I to need a gasket?
Andy FZS
« Reply #33 on: 19 April 2015, 01:58:02 pm »
I struggled to find a gasket easily was probably going to have to be a genuine yamaha one,  so I just cleaned up both faces and put a thin coat of gasket paste on. So far no dramas all seems good.
Peasy
« Reply #34 on: 19 April 2015, 02:02:12 pm »
Just done mine, dead easy really. I replaced my gasket.
