Date: 08-05-26  Time: 21:37 pm
Author Topic: C-Spanner..  (Read 5495 times)
infiniteloop
C-Spanner..
« on: 26 March 2015, 04:26:53 pm »
I'm after a C-Spanner to adjust the preload on my '98 Fazer. Found this one on eBay but just wanted to check with you guys if it's the right one.
http://www.ebay.co.uk/itm/290977138037?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Cheers..
Punkstig
Re: C-Spanner..
« Reply #1 on: 26 March 2015, 04:46:30 pm »
Don't see why not, cheaper than a hagon one which is the correct size too!
infiniteloop
Re: C-Spanner..
« Reply #2 on: 26 March 2015, 04:49:49 pm »
Cheers punk…I noticed that they come in different sizes & just looking for confirmation that this one is the correct size
anutz
Re: C-Spanner..
« Reply #3 on: 26 March 2015, 05:38:15 pm »
I am trying to adjust my shock as well - struggling to get the thing to turn!
Have the correct C-spanner....taking the gear shift off to give better access - the guard blocks things a little...
rhinoeli
Re: C-Spanner..
« Reply #4 on: 26 March 2015, 06:05:45 pm »
Needs some brutal force especially in high preload settings.
Punkstig
Re: C-Spanner..
« Reply #5 on: 26 March 2015, 06:13:15 pm »
You are using the extension bar on the end of the spanner right!?
anutz
Re: C-Spanner..
« Reply #6 on: 26 March 2015, 07:46:38 pm »
er no.... :D
Once i did it was easy....  :b
Thanks
anutz
Re: C-Spanner..
« Reply #7 on: 26 March 2015, 09:56:01 pm »
So here is mine, no idea if i measured the correct thing, but it may help...
infiniteloop
Re: C-Spanner..
« Reply #8 on: 27 March 2015, 01:53:36 pm »
Cheers for the help & pics…but I'm still none the wiser whether this C-Spanner on eBay is the correct size or not..??  :look
Re: C-Spanner..
« Reply #9 on: 27 March 2015, 02:16:03 pm »
It is probably seized. Spray the area above and below the ring with WD40 and turn it down one notch before trying to turn it up.
You will need to use the extender on the handle to get the extra leverage. That is the piece at the top of the picture below
http://www.fazerspares.com/images/items/itm_923_12369778101_l.jpg
noggythenog
Re: C-Spanner..
« Reply #10 on: 27 March 2015, 02:24:26 pm »
Make me an offer on a standard fzs600 one if needs be......i have one in the shed as unfazed has posted up.
Been a while since the noggyshop (Tm) did business.......cue christo now telling us that deefer has complete tool kits :b .
infiniteloop
Re: C-Spanner..
« Reply #11 on: 27 March 2015, 03:25:26 pm »
PM sent noggy..
Jules-C
Re: C-Spanner..
« Reply #12 on: 27 March 2015, 04:58:59 pm »
The standard tool kit. If I remember right you could take the back wheel off with it but not the front.  Bit Yamaha probably just expect you to adjust chain with it
noggythenog
Re: C-Spanner..
« Reply #13 on: 31 March 2015, 06:43:44 am »
Anyone know what size allen key that is.????
anutz
Re: C-Spanner..
« Reply #14 on: 31 March 2015, 03:37:26 pm »
I have 2 in my kit for some reason, a 5mm and a 4mm key, taking the measurement from parallel edges
noggythenog
Re: C-Spanner..
« Reply #15 on: 31 March 2015, 03:51:19 pm »
Cheers Anutz...mine doesnt have any...but it does have a set of feeler gauges...hmmmm
Jules-C
Re: C-Spanner..
« Reply #16 on: 31 March 2015, 05:16:22 pm »
Think it's a 5mm in the toolkit. For taking the side panels off
noggythenog
Re: C-Spanner..
« Reply #17 on: 31 March 2015, 09:26:50 pm »
Infiniteloop......will have to be Friday i send you this, cross reference reveals a couple bits i need to rake about in the shed for mate.
anutz
Re: C-Spanner..
« Reply #18 on: 31 March 2015, 09:56:54 pm »
wish i had some feeler gauges...
