Date: 08-05-26  Time: 00:26 am
Author Topic: 70mph in top gear???  (Read 15715 times)
Re: 70mph in top gear???
« Reply #25 on: 25 March 2015, 02:02:09 pm »
Its odd that the speedo is not an MOT test item
rhinoeli
« Reply #26 on: 25 March 2015, 02:40:38 pm »
engine won't need to work as hard going down hill as it would going up hill for the bike to reach 70mph
RPM is the same uphill and downhill if the clutch is engaged. It has nothing to do with the "work".
midden
« Reply #27 on: 25 March 2015, 03:36:40 pm »
Ok I'm with ya now.
But I'm still over 6k at 70mph  standard bike  ;)
AndyL
« Reply #28 on: 25 March 2015, 05:32:59 pm »
Mine reads about 5,800 or 5,900 at 70mph
greenman
« Reply #29 on: 25 March 2015, 05:37:46 pm »
Ok that got some very mathematical responses, when I say 61/2k rpm, I use this as a rough guide. I have a Speedo that occasionally goes weird, apparently I was doing 125mph around a roundabout I usually take at least than 30 a couple of weeks ago so when it was behaving itself I checked and displayed 70mph is just under 6500rpm = won't get nicked.
midden
« Reply #30 on: 25 March 2015, 05:57:10 pm »
Commuting to work I feel compelled to jump off and stand corrected.  70mph between 5800 and 6 rpm, 6500 is my normal riding area  :o sorry Rhinoela
the cueball
« Reply #31 on: 25 March 2015, 06:12:51 pm »
thanks everyone, very interesting answers...  :rollin
Jules-C
« Reply #32 on: 25 March 2015, 10:00:23 pm »
Check the route of the speedo sensor wire in particular by the brake disc.  Weird speedo readings are often caused by the edge of the disc wearing through the insulation and contacting the copper wire and sending confusing pulses to the speedo
Beeblebrox2nd
« Reply #33 on: 26 March 2015, 02:28:34 am »
Popping down the road for a jolly jaunt shows that at an indicated 70mph, my tachograph is reading 5900rpm, in standard gearing in top gear.
clayt74
« Reply #34 on: 26 March 2015, 05:24:05 pm »
Yep I get 5800 at 70mph standard bike! There is also quite a variance depending on tyre condition n profile. A few extra mm in tread has a large impact on the circumference of the front wheel hence a difference in speed reading..... Also how much tread on rear tyre will also affect the drive ratios.
Hehe I await the flaming :)
greenman
« Reply #35 on: 26 March 2015, 10:29:21 pm »
There is a nick in the the insulation by the disk, I just need to get around to getting it sorted but until then.......
Jules-C
« Reply #36 on: 27 March 2015, 12:27:53 am »
......wrap a bit of insulating tape round it to stop water getting in and leave for about 7 years.
It was good insulating tape its not even been replaced!
YamFazFan
« Reply #37 on: 05 April 2015, 01:13:26 pm »
My 600 is as standard as they come & top gear at 70mph is a fraction over 6000rpm. Maybe 6100'ish.
Correction  :o :o :o: Just been out on the bike for the first time in ages & made a special point of double checking this figure. At 70mph on the speedo the tacho is reading, as close as I can tell, 5650 RPM.
freeware
« Reply #38 on: 10 April 2015, 01:26:53 pm »
Standard gearing from my POV:
« Reply #39 on: 10 April 2015, 05:42:25 pm »
I make mine to be 5850 rpm standard bike, dosent look quite like 5900
