Date: 08-05-26  Time: 09:39 am
Author Topic: Sprocket Washer Bent?  (Read 18212 times)
anutz
Re: Sprocket Washer Bent?
« Reply #25 on: 20 March 2015, 05:07:07 pm »
....for anyone who has taken the sprocket cover off.....did you need to replace the gasket....mine seemed to have been so badly caked in rubbish its un-usable
Paulfzs
« Reply #26 on: 20 March 2015, 05:26:05 pm »
it has a gasket?
it doesn't hold oil i don't see why it would have or need one.
rhinoeli
« Reply #27 on: 20 March 2015, 05:32:46 pm »
it has a gasket?
I also had some sealing glue on the front mating surface of the sprocket cover. It is only for preventing chain oil "leaking" out to the front I reckon.
« Reply #28 on: 20 March 2015, 06:27:09 pm »
it has a gasket?
Yes that is it but most people do not refit without any probs although you might have to adjust the clutch to compensate even for that tiny distance
YamFazFan
« Reply #29 on: 20 March 2015, 08:42:28 pm »
The gasket seems quite expensive for what it is tho. Pretty sure it's around £25. I've always wondered how necessary it is to replace it.
anutz
« Reply #30 on: 20 March 2015, 09:31:28 pm »
if its to stop oil leaking out i will apply a thin coat of something to the surface of the cover when i re-assemble i think....
Jules-C
« Reply #31 on: 21 March 2015, 09:14:56 am »
£6.00 :eek...half that from yamahaha.
Still a lot better deal than this offering on fleabay
http://pages.ebay.com/link/?nav=item.view&id=121445661911&alt=web
Punkstig
« Reply #32 on: 21 March 2015, 09:28:00 am »
No one seems to know what the gasket is for- it can't be there to stop any fluids leaking out as there's a big hole on the right of it for the chain!
stevie-g1968
« Reply #33 on: 21 March 2015, 10:22:22 am »
was meaning I think the price around £ 2.50 I think....but 15 quid for the usless 9mm nut....having a larf..
rhinoeli
« Reply #34 on: 21 March 2015, 10:39:13 am »
It do stops leaking chain oil to the front. What else could be its function?
anutz
« Reply #35 on: 21 March 2015, 08:08:09 pm »
If anyone else has done this, when you re-assembled things, did you have to adjust your clutch lever?
When i pull the clutch fully in, there is still drive to the back wheel, when its on the center stand and i put it in first with the clutch in, the wheel has positive drive, extremely weak but its there....
Assuming adjusting the cables will solve?
« Reply #36 on: 21 March 2015, 08:25:49 pm »
Should really be adjusted from the bottom end first then the lever end.
« Reply #37 on: 21 March 2015, 08:29:38 pm »
That phah nom eh nom (help please) is normal when on the stand, but in theory if you had a gasket and removed you may have to adjust the clutch, when you look at how the mechanism works, that long leaver travel only translates into a very small push on the clutch push rodd  to operate the clutch and so a very slight change in distance caused by removing the gasket could make a difference
YamFazFan
« Reply #38 on: 21 March 2015, 08:37:43 pm »
I wouldn't spend too long trying to eliminate that. As long as the drive is only very weak, as you say it is, that's pretty normal & to be expected on wet sump bikes. It's an effect where the oil between the clutch plates creates drag.
anutz
« Reply #39 on: 21 March 2015, 11:47:13 pm »
Thanks all, i think its normal based on the comments, and there are no other issues
midden
« Reply #40 on: 22 March 2015, 01:47:08 am »
Gasket could be there to aid the tightening of the bolts. Allowing some sort of compression between the two metal edges
His Dudeness
« Reply #41 on: 22 March 2015, 01:56:55 am »
That's a sports gasket. Makes the bike go faster. I've three of them on mine. Had four on it but I couldn't keep the front wheel down so I had to take one off
Punkstig
« Reply #42 on: 22 March 2015, 09:13:37 am »
With that many gaskets whatever you do don't add a power band as well, you might flip the thing!
anutz
« Reply #43 on: 22 March 2015, 05:27:51 pm »
OK, 170 miles later and its running sweet :) - looking for a replacement gasket anyway, anyone improvised with their own gasket?
Andy Clap
« Reply #44 on: 22 March 2015, 05:50:12 pm »
£6.00 :eek ...half that from yamahaha.
Yamaha dealer did mine Free of Charge 2 years ago on an 11 year old bike!  Worth asking  :)
