Date: 07-05-26  Time: 09:57 am
Author Topic: TPS issues (cont)  (Read 15662 times)
Re: TPS issues (cont)
« Reply #25 on: 04 March 2015, 06:26:05 pm »
Does the needle alternate between 0rpm and 3000rpm when the TPS is unplugged?
Yup, all of them do this
Then surely that means the info is getting to your clock in the correct manner meaning the system is working but your TPS collection isn't.  :'(
jonest27
« Reply #26 on: 04 March 2015, 09:44:08 pm »
I'm beginning to think this too.
But also I'm wondering if my actual throttle position is wrong somehow and that's what's giving the 10,000 reading. Maybe the TPS's are reporting what they are seeing. I'm just unsure how/what to adjust throttle-wise to see if that moves the needle.
Any ideas?
« Reply #27 on: 04 March 2015, 10:55:16 pm »
Contact the breakers and say it's faulty.
Make sure you have the right one, they'll normally mark them.
jonest27
« Reply #28 on: 05 March 2015, 12:40:16 am »
Yea I could take it back there, that wouldn't be an issue, but it's the only one they had so won't get a replacement
Paulfzs
« Reply #29 on: 05 March 2015, 03:09:41 am »
know anyone nearby with a 100% working one?
jonest27
« Reply #30 on: 05 March 2015, 03:53:13 am »
I only know 1 other person with a Fazer  but havent seen him for a while since he moved jobs. I emailed him about it but havent heard back yet.
Paulfzs
« Reply #31 on: 05 March 2015, 11:06:33 am »
where abouts are you?
try using the members map to see if anyone's nearby
http://foc-u.co.uk/index.php?action=profile;u=7685
^^^ richard is breaking a fazer, maybe itll be worth asking if he can test the tps on the one hes breaking see if he can get 5000 and ask kindly if he will post it out to you if you pay postage to test it then either post it back or buy it if it works for you?
if it works > you have 3 broken tps's
if it doesnt work> other bike issue.
jonest27
« Reply #32 on: 05 March 2015, 08:08:33 pm »
Cheers for this, I didnt even think of checking the member map.
There are 2 guys quite close to me. I'll message them and see if they can help.
I'll also send a message to the guy you mentioned and see if he can help.
« Reply #33 on: 05 March 2015, 08:27:15 pm »
My money's still on 3 dodgy TPS units.
« Reply #34 on: 05 March 2015, 08:48:10 pm »
There is a very simple test to check if the TPS is outside the spec if you cannot get it to move from 10000.
Set the TPS to test mode (disconnecting reconnecting with ignition on).
Remove the TPS screws/bolts completely
Rotate the TPS until it can be set to 5000
Check the location of the screw/bolt holes in relation to the screw/bolt holes on the carburettor.
If holes are way off way off or you cannot set it to 5000 change the TPS. :thumbup
jonest27
« Reply #35 on: 05 March 2015, 09:06:54 pm »
Methinks you're right,
Just spoke to a mate of mine (the guy I mentioned earlier) his is at 10,000 too, he's gonna try and adjust it at the weekend, if he is able then I'll try it on mine and we'll know for sure.
jonest27
« Reply #36 on: 05 March 2015, 09:08:18 pm »
Hiya,
I've tried this. I can't get it to move at all, whether it's got the screws in it or not, no matter how much I rotate it, it still stays at 10,000
Ebme Geek
« Reply #37 on: 05 March 2015, 09:13:44 pm »
Darrsi may be right, 3x duff, and agree with unfazed, would have thought at least one of the three might be able to get the '0' reading even if they are badly worn at the sweat spot
but also I remember what you said -
I thought that if they are at 10, 000 and I moved it passed the "sweet spot" then it would jump to 0.
I have tried moving them really slow,( I've even put them on backwards and then turning them) but it just sit's at 10,000
and you said all three were the same, have you checked the connections to the ignitor module yet ?
If you have a meter, or could get one, really would be interested to know what resistance measurements you got off the three sensors like I put in reply #24, or just turning the centre without them on the bike.
jonest27
« Reply #38 on: 05 March 2015, 09:18:39 pm »
Havent been able to check resistances etc as I'm in work for the next 4 days (night shifts 12hr shifts ) I'm actually in work at the moment lol.
When I get a chance though I will definitely do this and post the results.
