Date: 07-05-26  Time: 14:22 pm
Author Topic: Restricted???  (Read 45178 times)
Silverlegacy
Re: Restricted???
« Reply #100 on: 04 March 2015, 08:29:02 am »
When i checked my air filter not so long ago i found some of that sludge in the air box? wasnt sure what it was so cleaned it out? but cant remember seeing any last time i checked it?? not sure what causes that?
Punkstig
Re: Restricted???
« Reply #101 on: 04 March 2015, 08:42:00 am »
Engine breather hoses lead into air box, any oil pushed into the air box will mix with moisture causing your milky gunk, it's not a problem as that is happening outside the engine, if you see that mixture through oil sight glass or when changing oil that's when you need to worry!
Silverlegacy
Re: Restricted???
« Reply #102 on: 04 March 2015, 08:52:09 am »
Thanks punkstig.
Luckily it's not like that in the engine.
Punkstig
Re: Restricted???
« Reply #103 on: 04 March 2015, 11:48:21 pm »
Speaking of k&n filters I just find out I have one - on the boat engine!
Silverlegacy
Re: Restricted???
« Reply #104 on: 05 March 2015, 03:37:37 pm »
Hi again,
Was doing some more research into this lean running thing.
A few sites have mentioned about adjusting the carb needles to make the engine run slightly richer? as mines running lean i am not sure if this will help any?
My Dynos on Page 3 i think so not sure if that will help to see if making the bike run slightly richer will help calm down the problem or even if it can be done at all?
I might have the wrong end of the stick (or needle)
thanks all
Re: Restricted???
« Reply #105 on: 05 March 2015, 04:30:51 pm »
Raising the needles a notch will richen it up slightly, but are you sure you want to get into tinkering with carbs? It'll mean quite an expense in further dyno runs to check the effect and it seems to me you're feeling something that isn't visible on the graph anyway as the power curve looks quite straight.
If the bike is running excessively lean (and that air/fuel ratio curve looks pretty similar to the one Red98 posted) you'd get pinking which should show up on the power graph. I can't think why it should appear on the road, but not on the dyno, but you could check by running a tankful of higher octane fuel through it to see if that makes a difference.
Silverlegacy
Re: Restricted???
« Reply #106 on: 05 March 2015, 05:14:11 pm »
Hi,
It's more to do with the air to fuel.
On the bottom graph it shows the lean patch at 6-7k rpm.
That's what I feel on the road, so matches perfectly with the feeling I get, although once you push past it, it improves. Not that I get much chance to thrash it about.
Just thought that maybe adjusting the needles might help push that lean patch a little higher up the Rev range .
Fazafou
Re: Restricted???
« Reply #107 on: 05 March 2015, 05:51:46 pm »
I was in a similar situation but different vehicle (long story) and ended up buying an air fuel ratio sensor and gauge off Amazon. While it was about 120 quid, when compared to repeat dyno sessions it's a cheaper alternative and you have a sensor and gauge to keep.
Either just shove it up the exhaust or cut a hole after collector box and brazed the collar on to fit the sensor (before any cat).
Works brilliantly and you can see the AFR in real-time as you're tuning and even while riding if fitted into the exhaust properly.
This way you can make adjustments to needle heights and see where it leans out in rev range and by how much.
I don't know if you want to go this route, but I learnt more about carbs in that one tune up than I have in over 20 years riding, so you could use it as a learning curve too :)
Silverlegacy
Re: Restricted???
« Reply #108 on: 05 March 2015, 06:03:22 pm »
Cheers fazafou, I will have a look at that and see.
It's not a massive problem with the bike, it runs really smooth below 6k rpm , so just up shift before I get there, do a bit more low speed commuting than high speed journeys .
Paulfzs
Re: Restricted???
« Reply #109 on: 05 March 2015, 06:49:35 pm »
i had aweak spot about 4-6k then after that the front forks would extend and it would fly off... nothing better than slowly going from 4-6k then pinning the throttle :D  :evil
Re: Restricted???
« Reply #110 on: 05 March 2015, 08:57:28 pm »
Remove the Air filter, hold the throttle open full, using a mirror and small torch/light look in to see if there are restrictors in the inlets.
If there are no washers in the inlets remove the tops of the carbs to see if a yamaha restrictor kit is/was fitted.
See pic
Punkstig
Re: Restricted???
« Reply #111 on: 05 March 2015, 09:11:34 pm »
Riding around below 6k rpm, what's that all about?
Silverlegacy
Re: Restricted???
« Reply #112 on: 05 March 2015, 09:32:17 pm »
Bike been dynod so definitely not restricted.
Nice I get the bike up to 6k it started to feel strained and a bit vibey. So tried to keep it below and just shift up as I hit 6k . Not ideal but bike runs really smooth that way, just not overly nippy.
After reading stories of people getting there's jetted and either being worse or doing nothing I don't think I want to spend £300 getting it sorted.
So just trying to see what else I can do, wanted a new exhaust but heard it could lean the bike out even more which might be bad news.
Might try adjusting carb needles one notch and see if it makes any difference?
Re: Restricted???
« Reply #113 on: 05 March 2015, 09:47:10 pm »
Check the charging, a slightly over charging regulator can cause similar symptoms
Silverlegacy
Re: Restricted???
« Reply #114 on: 05 March 2015, 10:07:04 pm »
Not sure how to check this as not overly technical?
Although I have read through a old thread and that was the problem, so might very well be?
I'm pretty sure I read somewhere about engine charging the battery at certain revs? Although I don't know the technical details sorry.
Bit of a tech noob on here, so appreciate everyone's knowledge and patience.
Punkstig
Re: Restricted???
« Reply #115 on: 06 March 2015, 07:29:08 am »
The power comes in after 6k, riding it below that and it'll never be overly nippy no matter how much you spend on Carb setups, air filters and exhausts!
rhinoeli
Re: Restricted???
« Reply #116 on: 06 March 2015, 08:01:49 am »
I would certainly suspect something in the carbs:
- leaky diaphragms
- one or more jets blocked
- float level too low
Sooner or later you'll have to take the carbs out, check them, clean them...
Other thoughts:
- fuel filter blocked?
- fuel pump?
- TPS?
Silverlegacy
Re: Restricted???
« Reply #117 on: 06 March 2015, 08:04:17 am »
If I can work out that issue between 6-7 k then hopefully it will give me an incentive to ride it more for fun rather than just commute, it's one of the only bikes I've owned I've not used of a weekend for rides out.
Might look further into this regulator thing?
I did notice something with the lights and lights on the clocks getting slightly dimmer when it was still dark around 7am, probably more so the lights on the clocks, although it has got an extra temp gauge and a analogue clock fitted to it drawing power? although doubt these are high usage items?
Silverlegacy
Re: Restricted???
« Reply #118 on: 06 March 2015, 10:45:19 am »
- leaky diaphragms
Other thoughts:
- fuel pump?
- TPS?
Ive tried to check as much as i can,
carb rubbers not leaking, although not cleaning carbs yet as might be a bit beyond me to be honest.
I fad fuel filter off, blew it out and cleaned it and its ok, not sure about fuel pump but seems ok? Ive adjusted TPS when i did my carb sync and its fine.
Starting to wonder now after reading through Red98's Stutter thread as to whether it might have anything to do with the regulator? although symptoms seems similar, ive probably not done a very good job of putting them into words.
rhinoeli
Re: Restricted???
« Reply #119 on: 06 March 2015, 11:23:37 am »
I am talking about the diaphragms inside the carbs, not the inlet rubbers.
Silverlegacy
Re: Restricted???
« Reply #120 on: 06 March 2015, 11:29:19 am »
well not had carbs apart so cant check this, might have a look in the haynes manual see how big a job it is, im sure its not going to hurt to at least look and clean that carbs, as could obviously tick a few things off the list in one go.
Paulfzs
Re: Restricted???
« Reply #121 on: 06 March 2015, 12:01:21 pm »
diaphragms are easy to check.
take seat off
take tank off
undo the 2 10mm bolts on the mount for fuel pump and coils.
move it out of the way
2x phillips screws on each carb top.
take the black cap off watch for the spring and loosing screws.
pull out the black rubber bit inside and hold it up to the light to inspect for holes.
push the needle out and check which setting the E clip is on.
push needle back in
put back into carb
cap back on the correct way, it has a little bit sticking out that should match the carb top
move on to next and make sure the E clip is in the same place whilst checking diaphragm.
Silverlegacy
Re: Restricted???
« Reply #122 on: 06 March 2015, 12:10:02 pm »
Cheers for that Paulfzs.
Pretty sure i can follow those easy instructions :-)
I dont mind tinkering a bit to see if i can resolve it, just doubt i can do anything too major.
But appreciate the help a lot :-)
Re: Restricted???
« Reply #123 on: 06 March 2015, 02:09:14 pm »
Did this happen suddenly of was it a gradual thing?
Silverlegacy
Re: Restricted???
« Reply #124 on: 06 March 2015, 02:16:37 pm »
pretty much since i had the bike? which was around July time last year.
I put up with it for a while but then started looking on here for a cure for it.
I tried to iron out the little niggly things like the headlight buzz and had it serviced and new chain and stuff on there.
I can live with it as i only use it to daily commute to work and roads are pretty slow where i live and only 7 mile commute through town (30) roads and a bit of a 50 main road, so if i just keep the revs down and change up early its ok, but i should be able to ride the bike like its supposed to and use the extra power if i need to with out it feeling like somethings wrong with the bike.
Like i said before i am probably doing a terrible job of describing the noise/buzzing and obviously makes it hard for people to help me diagnose the fault.
When it was dyno'd all the guy said was its running lean at 6-7k and could do with being jetted, but as there a dyno jet dealer i guess this might just be a ploy to make money and several people on here have commented saying that its not done there bike much good.
I keep going through different posts on here and a few point towards different things, so trying to check as much as i can but trying to take every ones advice on board and see if i can get it sorted.
