Date: 23-04-26  Time: 19:16 pm
Author Topic: Bugger  (Read 11091 times)
AyJay
Re: Bugger
« Reply #25 on: 31 May 2015, 10:03:55 pm »
Finally swapped to the summer bike and whipped off the radiator today to take a look. Oooh dear. The mounting lugs are all in a horrible state - one snapped clean through the others have so much corrosion it's almost like delaminated plywood.
Anyone know of a FZS1000 radiator for sale. None on eBay bar a chinese copy. Which might be ok for 80 quid
IMG 1529
IMG 1529
IMG 1533
IMG 1533
This is the second radiator as the previous sprang a leak but although I've still got it, and it's not really worth repairing as it's not that much better. I guess this is what 7 winters of salt does to a Fazer radiator. The retaining rings on the header pipes are about 1/3 of the thickness they were originally too.
PaulSmith
Re: Bugger
« Reply #26 on: 02 June 2015, 11:50:59 am »
Talking to the guy that repaired mine, he said that rebuilding the rad for a gen1 fazer would not be a problem, including making new mounting points. He said that the main section was pretty standard size so he would cut it out and replace it with one from a car, keeping just the original side pieces where all the hoses connect. He didn't seem to think it would cost much either. Since you have effecivly have a spare rad, it might be worth finding your local specialist and seeing what they can do with it.
(The gen2 has a curved face which would make this much more tricky. Not impossible, but not cheap)
Re: Bugger
« Reply #27 on: 02 June 2015, 06:02:31 pm »
At £45 for the hose and £11 for the clip, I think I will pick up some rad-weld on my way home.
Radweld is for bodging rads in 60s era Fords and Austins.  Has no place in a high performance motorcycle motor, IMHO. ;)
 :agree a cheap repair with possible expensive consequences
RMT1983
Re: Bugger
« Reply #28 on: 02 June 2015, 07:04:56 pm »
Ive got a radiator in the garage....................
Pm me if you still need one
AyJay
Re: Bugger
« Reply #29 on: 03 June 2015, 11:16:30 pm »
PM sent RMT....
