Date: 07-03-26  Time: 20:44 pm
Author Topic: battery optimiser?  (Read 1712 times)
taylor
battery optimiser?
« on: 25 January 2015, 06:54:19 pm »
 just put some leky in the bike shed, I have a trickle charger, albeit a cheap one, I have been told to get a optimiser any advise lads, I have been looking for hours there are loads of them,? advise pleaseee.
Re: battery optimiser?
« Reply #1 on: 25 January 2015, 08:07:40 pm »
I have a yam branded one made by c-teck who do the branded ones for jag or something, I have a hard wired connection connected to the battery on a short lead that curls up and tucks under the seat when not in use.
Not cheap though but it is cheaper if you get a bike only one whereas mine is car and bike (whatever difference that is)
slappy
« Reply #2 on: 25 January 2015, 08:20:14 pm »
I got a Halfords cheapo 3 years ago, still works perfectly. Came with 2 leads to connect it to battery, one with crocodile clips on and one so you can have a permanen connection to battery so you can just connect it very easily, I think that just about every charger comes with similiar leads.
I used to have an Oxford one that cost over £60 but it lasted only two years before it just decided to die, the Halfords one cost £25.
« Reply #3 on: 25 January 2015, 08:58:16 pm »
Here you go
http://www.optimate.co.uk/accumate.htm  Its their base model I've had one for about 15 years now it's never missed a beat I've also got their later type http://www.optimate.co.uk/optimate%204%20dual.htm.
The latter is a a bit cleaver at checking, can charge the later/gel type batteries and now canbus compatible it's up to you.
« Reply #4 on: 25 January 2015, 10:21:47 pm »
Nah, this is the base model  :lol
http://www.optimate.co.uk/optimate%202.htm
And a cracking job it does at charging dead flat batteries. Well worth it.
« Reply #5 on: 25 January 2015, 10:41:58 pm »
I'll also put in a good word for the Optimate, but do remember that whilst it will check voltage level, it doesn't do Load Testing so (as I found out recently) the battery may seem fine as it's got plenty of volts, but is sorely lacking in amps when you try to start the bike :(
taylor
« Reply #6 on: 26 January 2015, 07:32:48 pm »
cheers gents,
stevierst
« Reply #7 on: 27 January 2015, 05:30:56 pm »
I bought a cheap one from aldi and it wrecked 3 bike batteries!
Get yourself a decent one, cheaper in the long run.
« Reply #8 on: 27 January 2015, 05:59:09 pm »
I have an Optimate for years and it is a great reliably unit. :) No hesitation in recommending one
