Date: 26-05-26  Time: 06:50 am
Author Topic: R1 gear linkage mod ?  (Read 2970 times)
Woodzey80
« on: 30 December 2014, 04:48:54 pm »
Anyone know if this looks like an r1 gear linkage arm ?
Has anyone on the forum done this mod to a fazer ???
Falcon 269
Re: R1 gear linkage mod ?
« Reply #1 on: 01 January 2015, 09:23:30 am »
It could be but if it is, I believe it's from an original '98 model 4XV.  If that's right, I don't think it will fit the Fazer in the way you might be hoping.
Best option for this mod is a 99 - 00 5JJ model R1 arm but later ones can also be used if you reverse the position of the rose joint.
Woodzey80
« Reply #2 on: 01 January 2015, 10:05:48 am »
Cheers, thanks for the advice !
nickodemon
« Reply #3 on: 01 January 2015, 12:06:39 pm »
I did the mod a few years ago. It basically shortens the travel of the gear lever. It makes it slightly stiffer to change gear because the travel is reduced, but it's a worthwhile mod in my opinion. :)  Ps.. make sure the linkage rod doesn't make contact through the frame. I had to file mine so it didn't touch when changing gear.
