Date: 15-05-26  Time: 03:16 am
Author Topic: Rear linkage  (Read 4262 times)
nivek24
Rear linkage
« on: 05 December 2014, 03:22:59 pm »
Putting the rear shocker back on, should the linkage be tightened up with the bike on the stand or off the stand.
or does it not matter.
thanks. :\
kevin
PieEater
Re: Rear linkage
« Reply #1 on: 05 December 2014, 09:43:01 pm »
I believe you get less play if you tighten the bolts with the bike on the side stand.
solorider
Re: Rear linkage
« Reply #2 on: 06 December 2014, 01:33:52 pm »
Shouldn't make no difference as the bearings are roller bearings.
Re: Rear linkage
« Reply #3 on: 06 December 2014, 06:06:05 pm »
 :thumbup
Does not matter as they are tightened onto the collar/spacer not the needle roller bearings
solorider
Re: Rear linkage
« Reply #4 on: 07 December 2014, 11:05:38 pm »
 :thumbup
it is nothing to with having a collar/spacer as bushes also have a spacer, a bearing can be tightened in any position but a rubber bush should be tightened in its resting position under load otherwise the rubber bonding will get damaged when moved to its working position, not that will affect many motorcycles.
Simon.Pieman
Re: Rear linkage
« Reply #5 on: 08 December 2014, 09:27:46 am »
 :thumbup
I agree, but oddly the play in the linkage (which you can feel by lifting the back wheel) is slightly less if you tighten the linkage bearings up with the bike on the side stand as opposed to the centre stand. I have no idea why it turns out this way but I seen it myself a couple of times. Bit of a headscratcher.....
solorider
Re: Rear linkage
« Reply #6 on: 15 December 2014, 07:27:17 pm »
 :thumbup
I tightened mine up on the main stand and I have no play in my linkages
Simon.Pieman
Re: Rear linkage
« Reply #7 on: 16 December 2014, 09:47:03 pm »
There's a chance you've done it too tight then. Even from new these linkages have a perceptible play in them when you lift the swingarm.
