Date: 08-05-26  Time: 23:22 pm
Author Topic: Condensation Problems (Maybe)  (Read 11067 times)
Simon.Pieman
Re: Condensation Problems (Maybe)
« Reply #25 on: 24 September 2014, 01:40:11 pm »
A trickle charger would probably be a good investment.
I agree, that's why I bought an Optimate III some years ago and keep the battery topped up with it :pokefun
Well that is probably the big problem. If you use an Optimate regularly how is it possible to tell if the battery is failing? (other than meter tests)
As a rule, I use an Optimate only if the bike has stood still for 2 weeks and largely discharged itself (or got very low). If the battery is a good'un it easily lasts a week between starts, it doesn't need an Optimate to hold charge for that long. Bad batteries do.
esetest
« Reply #26 on: 24 September 2014, 05:01:02 pm »
As I don't use the bike much in the winter , I take it off the bike early November and put it back on in early march , I bring it indoors and put it out the way somewhere , then once  a month when I,m going to take it out I put the battery on charge for  an hour , the cold will kill a weak battery .
Grahamm
  • Global Moderator
« Reply #27 on: 25 September 2014, 12:40:51 am »
The Optimate does have a built in tester where it switches between charging and then checking the charge stays in there, but I don't know what the tolerance on it is. I've not had it register the battery as "weak", but obviously that's not proof.
Grahamm
  • Global Moderator
« Reply #28 on: 25 September 2014, 12:42:19 am »
However I do, hence why I don't want to be spending time removing/ replacing the battery every time I want to go out.
And, of course, temperatures at the moment aren't at "battery killing" levels.
His Dudeness
« Reply #29 on: 25 September 2014, 12:55:21 am »
It's not difficult get a multimeter and test the battery or get a battery and try it. You're just wasting people's time debating the most basic things
locksmith
« Reply #30 on: 25 September 2014, 09:21:35 am »
Once, I had a knackered battery that was "OK" on the optimate, and that was less than 2 years old.
I stopped having alarms fitted and don't bother with a charger now.
YamFazFan
« Reply #31 on: 25 September 2014, 10:39:42 pm »
My last battery was less than 2 years old and wouldn't hold charge on the bike enough to even operate the fuel pump after a week without use,but it came up "OK" on the optimate (after recharging).Charging it up and leaving it off the bike it was still reading over 12v after 4 days,by which time i'm thinking I've got a discharge problem on the bike,but on the 5th day the voltage had suddenly dropped to 0.3v! and putting the multimeter back on took it into -volts.Fitted new battery & all is sorted :).
Dead Eye
« Reply #32 on: 25 September 2014, 11:25:07 pm »
Go home battery, you're drunk
Grahamm
  • Global Moderator
« Reply #33 on: 28 September 2014, 01:31:13 pm »
I have, as mentioned in the other thread.
Quote
Fine, you pay £50 for a new battery for me and if that turns out to have been the problem I'll pay you back.
If it isn't, I'll have it as a free gift.
Quote
Nobody is forcing you to read this thread, but thank you for your helpful comments.
« Reply #34 on: 28 September 2014, 01:44:27 pm »
I don't mean to put a spanner in the works, but battery chargers foc up as well.
I see it all the time at work as we have hundreds of them (no i can't get you one).
They look like they're charging, with all the lights showing up okay but they can be dud too, just like ropey phone chargers.
Everyone just presumes it's the battery but it's not always the case.
Just something else to consider that's all, i'll shut up now.  :tape
midden
« Reply #35 on: 29 September 2014, 12:01:20 am »
Have you tried disconnecting the battery completely then leaving it for a couple of days to see if it holds it's charge?
Just bump start it then, like I have the couple of times it's happened to me.  Mine has even flattened after a long ride just by leaving ignition on for a few minutes. I know the battery is on its way out but so far like you've mentioned it works fine after a bump start. So I put up with it but when it becomes a problem as it clearly has for you I'll just take the plunge and buy a new battery.
Grahamm
  • Global Moderator
« Reply #36 on: 01 October 2014, 06:56:02 pm »
Thanks to everyone for the advice and my apologies for the delay in replying, but my mother was taken into hospital a few days ago so I've had a few other things on my mind.
I did actually bite the bullet and buy a new battery, unfortunately I'm having *another* problem, this time with a stuck bolt, but I'll detail in a different thread as I think this one has run its course.
Doddsie
« Reply #37 on: 01 October 2014, 09:04:07 pm »
No need for apologies, some things are more important than others.
