Date: 25-05-26  Time: 11:25 am
Author Topic: gen 1 Misfire  (Read 14642 times)
Re: gen 1 Misfire
« Reply #25 on: 29 September 2014, 10:15:04 pm »
A faulty Ignitor would effect 2 or 4 cylinders.
An issue with the coil would effect 2 cylinders,
An arcing plug cap or problems with a carburettor could effect just one cylinder.
Corrosion withing the Plug cap can cause misfiring which can come and go.
Bypass the Ignition Key circuit to rule out the Ignition switch if necessary.
bwizz
Re: gen 1 Misfire
« Reply #26 on: 01 October 2014, 05:10:49 pm »
New coil came today , after fitting ,misfire fault has gone ! Can't be sure on the "Sudden death issue" ,Time will tell ! But i'm quite happy at £20 delivered for a new coil. I'll update after a good  long ride
Re: gen 1 Misfire
« Reply #27 on: 01 October 2014, 05:48:59 pm »
Sudden death issue could be corrosion in the connector to the pickup coil, located under the tank.
bwizz
Re: gen 1 Misfire
« Reply #28 on: 02 October 2014, 08:39:36 am »
I rode 30 miles with engine running well, last night , left the bike for a couple of hours and then back to the sudden death syndrome. Finally started after a lot of cranking. I wagged the side stand ,ignition key and kill switch neither of which seemed to make any difference. I only remember seenig two terminal blocks under the tank , both of which I separated  and WD 'd. This is weird having two electrical issues at the same time.
Re: gen 1 Misfire
« Reply #29 on: 02 October 2014, 10:57:46 am »
I think the coils are a red herring.
Ignition switch and/or the big white connector under the tank.  WD40 isn't much of a contact cleaner, either.  I really recommend replacing this connector with better quality individual connectors.  It's a known issue and even if it isn't the cause of your present misfire, time spent doing this will pay in the future. :)
bwizz
Re: gen 1 Misfire
« Reply #30 on: 02 October 2014, 12:16:27 pm »
I would think there is defo 2 issues , as I have had this, " not starting issue," months before the   misfire came on.
what does the black wiring plug "under the tank" link up , this was the dirtier of two
Re: gen 1 Misfire
« Reply #31 on: 02 October 2014, 01:40:13 pm »
In which case they should probably be upgraded with electric eels, but cod knows I'm probably talking pollocks  :rollin
Sorry  :o
bwizz
Re: gen 1 Misfire
« Reply #32 on: 02 October 2014, 02:17:46 pm »
Can't do any more as my sides have split!
stu1318
Re: gen 1 Misfire
« Reply #33 on: 02 October 2014, 05:42:31 pm »
well that's mine ok again.....new plugs fitted  :)
bwizz
Re: gen 1 Misfire
« Reply #34 on: 02 October 2014, 06:48:07 pm »
I took tank of again , I have thoroughly cleaned the white block. I also found a bunch of 4 terminal blocks in a large plastic cover . one of these had green pins , cleaned all these and  WD'd . Bike starts every time now but , again pick up is not clean!  Can't get my head round how last night it ran 30 miles perfectly. Might even treat it to new plugs as the last ones only a month ago were e bay cheepos possibly NJK copies. clutching at straws now. whats an ignitor ? re A faulty Ignitor would effect 2 or 4 cylinders. (Unfazed)
Re: gen 1 Misfire
« Reply #35 on: 02 October 2014, 08:28:22 pm »
Bwizz, I must apologise the pick up coil connector is under the right hand side cover, it is the TPS connector which is under the tank.
The pick up coil is linked to the EXUP motor, TPS, Speed Sensor, emergency stop switch and ignitor.
When I had the sudden stop problem I traced it to the dreaded green corrosion in the pick up coil connector.
Ignitor is Yamaha name for the the electronic ignition system and is the box under the seat next to the fuse box with Denso label, also known as ECU, CDI or ECM
bwizz
Re: gen 1 Misfire
« Reply #36 on: 02 October 2014, 09:14:56 pm »
Ok ta I thought you meant .The "what I thought of as the CDI unit" I'll have a geek behind the side panel tomorrow. i think the RAC man checked it though.  Uneven running fault seem to be affecting 1+4  both these plugs are showing signs of fouling
Re: gen 1 Misfire
« Reply #37 on: 02 October 2014, 09:55:29 pm »
Did you use the plug caps on the replacement coil? A few replacement coils I have bought in the past had corrosion in the caps.
Swap the plugs caps on Cylinders 1 and 4 with the plug caps on cylinders 2 and 3 and see if the fault follows the caps.
bwizz
Re: gen 1 Misfire
« Reply #38 on: 03 October 2014, 10:36:25 am »
I tried some kawasaki plug  caps " from the temporary coil"  on  1 and 4 , did not make any difference ! I took of the side panel , lots of terminal blocks there! pulled every one apart and cleaned +WD'd result no difference!  Not died since though!
I hung a plug on both no1&4 , massive spark on both. Two thoughs now , either these two plugs break down under load.
Or two cyclinders are flooding intermittently (Mikes suggestion area ), I'm going to try two plugs from my 600 tomorrow , not quite the same heat range , but might be interesting
bwizz
Re: gen 1 Misfire
« Reply #39 on: 04 October 2014, 11:55:02 am »
I fitted the 2 plugs from the 600, started up fine then within minutes ,I lost no 4, This would seem conclusive that no 4 is flooding constantly and no 1 intermittently.  This will have to wait till i'm in a better state of mind to thake the carbs of,
Re: gen 1 Misfire
« Reply #40 on: 04 October 2014, 01:27:20 pm »
I fitted the 2 plugs from the 600, started up fine then within minutes ,I lost no 4, This would seem conclusive that no 4 is flooding constantly and no 1 intermittently.  This will have to wait till i'm in a better state of mind to take the carbs of,
Push a clear plastic pipe onto the drain hole and tape on to the side of the carb. Loosen the drain bolt and and let it fill the pipe check the level of the fuel in the line in relation to the float bowl. Now start the engine and see if the height changes when the engine is running and being revved. See picture attached.
If levels are wrong it is either dirt or dodgy float valve seals.
If it is seals change all 4.
bwizz
Re: gen 1 Misfire
« Reply #41 on: 05 October 2014, 09:07:25 am »
Ta i'll give that a go,  Very difficult to get at no4 .
bwizz
Re: gen 1 Misfire
« Reply #42 on: 25 October 2014, 10:24:32 pm »
Just an update on the misfire.  Just started up the bike after not touching it for two weeks.  Started perfectly I have done a few short test rides since and still ok . Only thing I did after the last investigation session was to re'route the outer plugs leads slightly. Time will tell " if it stays ok"
Hope so as I was not looking forward to taking the carbs of.
