Date: 20-04-26  Time: 12:33 pm
Author Topic: jets  (Read 28302 times)
wutangbuzz
jets
« on: 20 August 2014, 06:28:42 pm »
I've stuck a race can on my fazer which makes it sound much more fun but its made a big flat spot early in the revs. Anyone know what jets I can use to get rid of this?
pilgo
Re: jets
« Reply #1 on: 01 September 2014, 08:25:47 am »
stick a K&N air filter in and see if that helps,been told that you dont need to re jet just for a freer breathing can,others on here might know otherwise? maybe get your carbs balanced,improved the feel of the engine when i had mine done.and cured the rattle i had from the clutch
stevierst
Re: jets
« Reply #2 on: 01 September 2014, 01:39:38 pm »
They're normally ok to fit an end can on, there may be something else wrong there!
I'd make a start with a Carb balance and see if that helps.
Re: jets
« Reply #3 on: 20 October 2014, 09:11:42 pm »
Do the carb balancing and tps adjustment. Makes a big difference. If you still think it's suffering, put a k&n filter in. No new jets are required. The fzs was over fuelled from the factory.
