Date: 08-05-26  Time: 03:45 am
Author Topic: Remove / Refit pipes - parts needed?  (Read 2346 times)
keratos
  • Guest
« on: 03 August 2014, 09:43:16 pm »
found this..
http://foc-u.co.uk/index.php/topic,90.0.html
1.Any seals/sealant/gaskets etc. needed when I remove and refit the downpipes headers and foot (into can)
2.Is this applicable to FZS600 "2000" model
3.Where are the pics from the above thread?
TIA
His Dudeness
Re: Remove / Refit pipes - parts needed?
« Reply #1 on: 04 August 2014, 10:52:22 am »
My advice is leave them unless they really have to be taken off. If you snap a stud you'll be in trouble
Panthor
« Reply #2 on: 04 August 2014, 10:55:44 am »
1.  Didnt use ay sealant when doing mine, didnt need it.  I Changed the circular copper gaskets at the head and just reused the one on the foot into can.
2.  Applies to all FZS600 (mines a 2003)
3.  not sure where pics are but its all pretty easy to do when you take a look at your bike.
didnt snap any studs on mine, did the soaking with WD40 once a day every day for 2 weeks before had though. (just be careful)
keratos
  • Guest
« Reply #3 on: 04 August 2014, 01:02:45 pm »
cheers Panthor.
Jules-C
« Reply #4 on: 04 August 2014, 01:48:44 pm »
I'd get a spare gasket for the header to end can join. The join doesn't always come apart cleanly. If you don't need it keep it till next time
keratos
  • Guest
« Reply #5 on: 04 August 2014, 02:06:45 pm »
confused :2guns so is the advice to change both head and foot gaskets , or not , or "suck it and see". The default to assume the worst case is usually safest best so assuming this I need copper head gaskets and the footer (to can) join ?
noggythenog
« Reply #6 on: 04 August 2014, 02:52:58 pm »
I think it depends on what end can and header combination you have.......when i took off my original end can i totally destroyed the gasket and my Simmi performance can fitted over it nice and tight and then the clamp tightened it up so much that i didn't need a gasket, same app,ied when i got stainless headers........but ive heard of others moaning about the seal on other cans not being good enough.
spyder
« Reply #7 on: 05 August 2014, 06:12:22 pm »
Used new copper seals for headers- only £6 from Motad, everything undid without prob. I think the end can could seal better but the MOT guy was happy with it
keratos
  • Guest
« Reply #8 on: 05 August 2014, 06:14:21 pm »
Jeez.. What am I worrying about.. At these prices I should just replace anyway. Cheers!
