Date: 08-05-26  Time: 01:44 am
Author Topic: [SOLVED] Diagnose my starter problem please  (Read 14139 times)
Re: Diagnose my starter problem please
« Reply #25 on: 26 July 2014, 06:50:40 pm »
Read what I wrote again. I said that Voltage reading are not an effective test, useful yes, but not always an effective test.
« Reply #26 on: 26 July 2014, 07:24:02 pm »
If the starter relay is high resistance then the voltage drop will occur across it giving a low voltage at the output.
In what way is that not an effective test?
keratos
  • Guest
« Reply #27 on: 26 July 2014, 07:51:55 pm »
Unfazed: sorry to disagree with you, but the voltage measurement is very useful. You can't have a 12v output from the relay with the motor not turning and blame the relay!
Precisely.
It can surely only be an issue from the 12+ starter relay output , along the lead, to the starter terminal.
Can't be the motor as this spins freely when hotwired .
What I did also was short the relay output with the 12 v battery terminal. Very close together and I used car battery jump lead croc clip to short the two. The motor turns every time so it can't be the lead to the motor either. And it's not the motor either or the grinding to/of it.
God this is annoying
« Reply #28 on: 26 July 2014, 08:14:12 pm »
Intermittent faults are a nightmare. All you can do to pinpoint it is to ignore the results you get when it's working OK and concentrate on those you get when in faulty mode.
Perhaps the next step is to try a voltage reading on the starter motor itself to eliminate the cable and connectors from the relay as being the cause.
keratos
  • Guest
« Reply #29 on: 26 July 2014, 09:00:10 pm »
Yep. But as above... I shorted the battery and relay output (to motor) and all is fine so it's not the cable from relay to motor
« Reply #30 on: 26 July 2014, 10:02:20 pm »
My point was that that may be a false positive… i.e the fault, wherever it is, wasn't exhibiting itself on those occasions. The 12v output from the relay when the motor didn't spin, on the other hand, is conclusive evidence that the fault lies downstream of the relay.
There are only a few connectors to look at, I'd be inclined to scrape and tighten all of them and if that doesn't chase the gremlins away, whip the motor out and check all's well inside. If I had to put money on it, I'd guess glazing of the armature/worn brushes is the likely culprit.
keratos
  • Guest
« Reply #31 on: 26 July 2014, 10:27:35 pm »
thanks for the help and persistence;
what I would say is that it is defo not the motor; the motor spins every time I short out the relay output to battery+. Every time; I've lost count, maybe over 100 times.
I have looked at the wiring diagram on 8-11 in the Yam shop manual. Ive tested, as much as I can, the terminals and looms. With ignition on, run switch on, I "hear" the cut off relay energise and I confirm voltage and continuity.
When I press the start button I hear the clunk of the starter relay , and confirm voltage and continuity. So no issues with any of the switches and cut-off relay otherwise the starter relay wouldnt energise when I press start.
When I get no engine start, I hold the start button (no spin) then whilst holding I short the relay+ and battery+ with a pair of big pliers, motor spins - this works every time the start switch fails to spin the motor; It cant be the motor or the cable to it from the starter relay. I cant be anything "upstream" from the starter relay or the relay would fail to energise when I press start (according the the wiring diagram)
All I can think of is some intermittent mechanical failure inside the  starter relay moving parts. I just dont get it. Its ridiculously illogical. I think I'll have to replace the starter relay anyway . So I have ordered a second hand one from eBay for £5 with 28day warranty. If it works, and removes the problem for 28days, I will buy a new one.
davidkent
« Reply #32 on: 27 July 2014, 02:38:58 pm »
Would it not be best test these things when its cold, ie before you've tried starting it on the button at all?
There's more chance then, that the results you get are 'true'.
If you've tried once or twice on the button before testing, the chances are that the third time, the testing time, has sorted the issue again and the readings are false?
Has been mentioned before but nobody actively mentioned trying it from cold before trying it on the button if that makes any sense...
keratos
  • Guest
« Reply #33 on: 27 July 2014, 03:22:06 pm »
It can happen cold, warm and hot. First thing in morning, during a rideout, after getting in, and after leaving it an hour, two,three hours. There is no pattern or logic.
I've ordered a new solenoid so will wait and see what that does.
keratos
  • Guest
« Reply #34 on: 01 August 2014, 06:07:52 pm »
hats off to unfazed...
cos I swapped out the starter relay and all is fine now.
but when I tested the relay all was fine - just goes to show ... manuals, guides, and manufacturer info is no substitute for good ole experience
cheers guys and apologies to unfazed who will have felt  ignored , but who is now fully vindicated and was right all along
Re: [SOLVED] Diagnose my starter problem please
« Reply #35 on: 01 August 2014, 07:54:27 pm »
Apology accepted Keratos.
Glad to see another fazer back on the road and not giving its owner grief :lol
It is most likely copper corrosion or burning of the the internal high current contacts.
I have seen it before when working for the telecoms company on high current copper bus bars contactors and my neighbours car a few years ago whose arrogant smart ass mechanic did not believe it either  :)
Dismantle the starter relay out of curiosity to see what is actually wrong with, which is what I did with the car solonoid to prove a point to my neighbours mechanic.  :lol
keratos
  • Guest
« Reply #36 on: 01 August 2014, 08:28:23 pm »
yes , point taken - twice , cheers for the humiliation  :o :b
keratos
  • Guest
« Reply #37 on: 01 August 2014, 09:32:26 pm »
Relay disassembled, partly, as the fault is identified. Note the underneath of the fuse holder, top left in the image shown inverted, the metal track that carries the high amp current from battery+ to starter motor,  has corroded away. Hence problem and hence increasingly intermittent ; used to start if I gave the side of bike a firm gentle nudge! Got to the point where it wasnt starting. What I didnt check is continuity across the two high amp terminals.  I need not have started to disassemble the bottom of the relay,  so I guess I was just showing where I was up to !
Jeez guys, we should just listen to unfazed
IMG 20140801 204154
IMG 20140801 204154
« Reply #38 on: 01 August 2014, 10:18:24 pm »
Actually keratos was not getting at you or trying to humiliate you and I was sincere in accepting the apology.  :thumbup Fair play to you for coming back on and saying what you said. :thumbup
Corrosion can do funny things with meter tests, the only way to test it properly is using a high current meter.
The smart ass arrogant mechanic said to my neighbour when he explained what I had told him said and I quote "What the foc would a fellow who fixes phones know about car electrics" :eek
He was insisting that the starter motor was faulty and it would cost 100 pounds, I got a solonoid from the breakers for a tenner and put it in for him.
I opened the solonoid showed him what the problem was and he took it back to mechanic who told him to foc off, he did and changed to a different mechanic which he has been using since  :lol
keratos
  • Guest
« Reply #39 on: 01 August 2014, 10:20:33 pm »
Actually keratos was not getting at you or trying to humiliate you and I was sincere in accepting the apology.  :thumbup Fair play to you for coming back on and saying what you said. :thumbup ...
no no no, I was only kidding, just messing around. I dont feel humiliated dear foccer, just kidding. Guess my humour needs to grow on people. naughty me  :evil
« Reply #40 on: 01 August 2014, 10:55:27 pm »
Yeah, but if you were not :lol
keratos
  • Guest
« Reply #41 on: 01 August 2014, 11:02:30 pm »
Yeah - its hard to find an honest, good, mechanic of integrity. I'm lucky to have one for mechanicals; however,  for electrics I'm okay (although I work with TTL and IC/ASIC/SOC in my day job) so do my own automotive electrical.  I've learnt something new through this episode though - and it's all about learning. There wont be another automotive relay that gets the better of me  :\ hopefully!
« Reply #42 on: 02 August 2014, 12:42:57 am »
 :thumbup
