Date: 08-05-26  Time: 04:53 am
Author Topic: TPS adjustment  (Read 20761 times)
Re: TPS adjustment
« Reply #25 on: 04 July 2014, 02:51:50 pm »
It's all over the place, I've no idea how it's happened to be honest. I've had the wheel if in the garage and can only assume I've whacked it or something. It did fall over the other day but I can't see how that would be able to bend it?!
If it's off the bike and "looks" warped then that's a different story, i thought you meant you had issues with braking.
If you thought the TPS was expensive, wait 'til you start looking for discs.  :eek
Re: TPS adjustment
« Reply #26 on: 04 July 2014, 02:54:30 pm »
You could always take a chance and buy a second hand original disc off Ebay if you want to keep the price down.
They work independently so you don't "have" to buy a pair.
Davew
Re: TPS adjustment
« Reply #27 on: 04 July 2014, 06:37:43 pm »
you're not wrong!  £190 EACH for Yamaha/EBC ones!!!!!
luckily through some incredible stroke of luck I got a second hand pair on eBay from someone about 10 minutes from my house for £60!  result!!
will just replace the warped one for the time being as they look pretty much identical in wear.
midden
Re: TPS adjustment
« Reply #28 on: 04 July 2014, 06:49:47 pm »
I've just balanced mine and didn't touch the tps,  just used the idle adjuster on no.1 carb.  runs beautifully :)
Re: TPS adjustment
« Reply #29 on: 04 July 2014, 07:38:21 pm »
I got a pair off a Foccer one here and they were bent as S hooks :'(
Have not seen or heard from him since
