Date: 26-05-26  Time: 23:20 pm
Author Topic: How hot does the end can get?  (Read 2054 times)
ChristoT
« on: 17 June 2014, 01:25:54 am »
As per title. I'd quite like to put carbon caps on my exhausts, but need a rough temperature to work to. They're free flowing, if that makes any difference.
Anyone ever taken the link pipe temp?
Thanks!
Chris
Re: How hot does the end can get?
« Reply #1 on: 17 June 2014, 09:38:03 am »
link pipe on mine gets pretty hot but the actual can is usually cool enough to touch even if I've been  on a long run.
Chris
ChristoT
« Reply #2 on: 17 June 2014, 10:31:49 am »
I'm going for worse case scenario here. If I build to link pipe temp, I know I'll be fine. Could anyone stick a thermometer on their link pipe after a run today?
Punkstig
« Reply #3 on: 22 June 2014, 08:52:08 am »
Not having a thermometer to hand I used my tongue instead, if my cup of tea was that hot I'd be happy, however, I'd like to point out my can would have a different temperature to anyone else's as it's a stubbied scorpion.
Are you after temperature for a standard can or aftermarket as the different flow rates will create a different temperature-
ChristoT
« Reply #4 on: 22 June 2014, 08:54:54 am »
Oh, of course. I'm after a pessimistic value to work to, but my cans will be dual free-flowing high level Scorpions
NorthWestern
« Reply #5 on: 22 June 2014, 09:03:21 am »
Titanium pipes start turning blue at about 350 iirc so the link pipe will be about that seeing as they go blue...  You won't make carbon able to withstand that temp. The end cap should be fine though
