Date: 30-04-26  Time: 08:57 am
Author Topic: air induction system  (Read 3876 times)
SWIFTY
« on: 05 June 2014, 10:49:52 pm »
 Got the info on removel, who can supply the kit for blanking off, or size of tap & thread size of   blanking bolts ( exhaust)  , Thanks SWIFTY. :rolleyes
mickvp
  • Global Moderator
Re: air induction system
« Reply #1 on: 05 June 2014, 10:59:40 pm »
I just got my Holeshot AIS removal kit in yesterday (doesnt need any tapping).
http://www.holeshot.com/fz1/ais_removal_kit.html
The other option is the ivans performance kit:
http://www.ivansperformanceproducts.com/R1Airkit.htm
Falcon 269
« Reply #2 on: 06 June 2014, 05:13:57 pm »
M8 socket heads for the exhaust stubs.  10mm is long enough.
Use a good quality M8 x 1.25 HSS tapered tap.  I repeat - tapered, good quality.  Not cheapo job from Aldi!
Use Search here to get more info on how to tap the stubs, particularly the outer pair which can't be done with a regular tap wrench.
PieEater
« Reply #3 on: 06 June 2014, 07:09:23 pm »
Looks like Pat removed the radiator to tap out his stubs - http://www.cartestsoftware.com/fz1/airinductionsystemremoval.html  :eek  don't know if you have to do this but the Holeshot kit is just a lot less hassle. If you're going the DIY route i.e. sourcing your own tap then don't forget you will need to blank off the hose connectors at the airbox and on carb #4. You could get an OEM cap and clip for the carb stub for not much money so it matches the rest of the carbs, you could probably find a bottle cap or something that would be suitable to blank off the airbox connector.
mickvp
  • Global Moderator
« Reply #4 on: 06 June 2014, 08:40:48 pm »
the instructions that come with the holeshot kit also ask you to drain the coolant and remove the radiator, so I imagine it needs to come out for access regardless :)
esetest
« Reply #5 on: 06 June 2014, 09:07:29 pm »
It would be a bit of a struggle  removing the AIS with the radiator on .
