Date: 10-02-26  Time: 05:15 am
Author Topic: Going naked?  (Read 15073 times)
Roly
Going naked?
« on: 09 May 2014, 07:48:10 am »
Just wondering if anyone has tips coverting a fazer to naked/streetfighter type bike.
Did this to my 53 reg 600 hornet but adapting clocks etc was a bit tricky. Would like to do on a budget if poss.
Anyone used the nose cone/headlight units available in great variety on ebay?
Thanks!
Punkstig
Re: Going naked?
« Reply #1 on: 09 May 2014, 10:01:33 am »
You obviously want one of these
http://pages.ebay.com/link/?nav=item.view&id=261472716702&alt=web
Being sold by a reputable good honest person, and I can tell you at the moment £5.01 will be the highest bid!
Par6
Re: Going naked?
« Reply #2 on: 09 May 2014, 05:14:27 pm »
I've just finished doing this to my bike. It was too good a deal to turn down, I bought the bike, 99 boxeye,  for £600, sold the headlight for £75, fairing for £180, indicators for £30, double bubble screen for £30 and handlebars for £20. I hate bikes with fairings, always disliked the way everything always points straight ahead even when your turning ! Anyway I then bought a set of renthal bars £30, a new 7" lc type headlight £40, renthal grips £10, mini indicators £15, xenon headlight bulb £5, bar clamps £20. New clamps are needed the way I did it because I needed the bolts to be extra long to attach the new bracket that the clocks bolt to.
The bracket/plate was made from 3mm ally plate, I drew around the clocks to give me the shape, cut it out with a hacksaw, eventually, then marked where the ignition barrel was and where the clamp bolts were and then cut and drilled to make it fit. It's hard to explain and was a lot of trial and error. The plate was then bent so that the clocks faced the rider. There is a 10mm gap between the plate and the back of the clocks and a solution was found in .."................gutter gaskets !, the rubber strips that seal gutter brackets were a perfect fit, they look like they were designed for the job and are held in place with a few blobs of superglue.
The result is excellent if I do say so myself and I now have a bike that points where it's going.
I will post pictures if I can work out how.
Roly
Re: Going naked?
« Reply #3 on: 09 May 2014, 06:21:28 pm »
This sounds just what Im after, pics would be great. Is there no gallery on the site?
I did similar with my hornet, tbh making the clocks fit in was the hardest bit. Selling parts on would help but Im more inclined to keep jic I resold, then the buyer would have both options. Im 100% with you on the fairing pointing straight ahead when you turn!
Roly
Re: Going naked?
« Reply #4 on: 09 May 2014, 06:42:29 pm »
http://www.ebay.co.uk/itm/390036334618?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
Like this ? Looks like it would use 2 headlights and still turn with you
Roly
Re: Going naked?
« Reply #5 on: 09 May 2014, 06:47:01 pm »
Geordi Sussex
Re: Going naked?
« Reply #6 on: 10 May 2014, 09:35:05 am »
Take the fairing off
You can cut the bracket down that the clocks sit on
Make sure what ever headlamp unit you get it is a proper bulb
I bought one and it had a small halogen bulb like what is used in kitchens
Needless to say it was rubbish and it got binned before I tried to put it on the bike
johna6968
Re: Going naked?
« Reply #7 on: 11 May 2014, 11:01:20 am »
http://www.ebay.co.uk/itm/281115038964?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
In the uk. Seems very cheap
Seen that fairing on a few bikes and tbh never looked right on any.. Hints at a shrunken sport bike top fairing thats out of proportion with everything.. Apologies in advance to anyone that has gone that route  :)
emjaydee
Re: Going naked?
« Reply #8 on: 11 May 2014, 11:30:08 am »
This is the look I'm going for, will be cheap to do.
ChristoT
Re: Going naked?
« Reply #9 on: 11 May 2014, 11:56:00 am »
Looks kinda cool, actually! But personally, I'd have Punkstig's flyscreen fairing, I reckon that would look awesome.  :)
Not sure about the lack of bracing on that can though....
midden
Re: Going naked?
« Reply #10 on: 11 May 2014, 12:24:08 pm »
LIKE button pressed many time  :)
Roly
Re: Going naked?
« Reply #11 on: 11 May 2014, 02:09:08 pm »
Yep thats the look! Single headlamp looks good. :thumbup :thumbup
The Gentleman Biker
Re: Going naked?
« Reply #12 on: 16 May 2014, 09:12:49 pm »
Have you made any progress on this? Mine is naked from the factory, I could provide any pictures you may need?
emjaydee
Re: Going naked?
« Reply #13 on: 16 May 2014, 09:20:06 pm »
Pictures would be great, thanks.
The Gentleman Biker
Re: Going naked?
« Reply #14 on: 16 May 2014, 09:52:36 pm »
Here are a few, anything you actually need? I'll get some closer pictures tomorrow.
emjaydee
Re: Going naked?
« Reply #15 on: 16 May 2014, 10:05:07 pm »
Looks fantastic  :eek .
Did the clock fit straight on or did you need to fit a different sender?
more pics of the headlight and clocks please, Thanks
The Gentleman Biker
Re: Going naked?
« Reply #16 on: 16 May 2014, 10:11:07 pm »
I don't know the ins and outs of anything 'extra' needed because this is from the factory like this (minus the clip ons). But as far as I know the clocks are the same as the XJR400 and the top yoke probably is too.
I'll have a look at grabbing some more detailed shots tomorrow.
keithfzs1000
Re: Going naked?
« Reply #17 on: 17 May 2014, 08:28:14 am »
be careful of all those cheap bikini fairings none will pass mot as no beam pattern, best off with an old lc350 headlight or any 7" round or mt03 fz6 depending on money available...mine has fz6
Par6
Re: Going naked?
« Reply #18 on: 18 May 2014, 02:14:29 pm »
I'd post some pictures of mine but all my pictures are on iPhone/iPad and I can't figure out how to post via these.
The Gentleman Biker
Re: Going naked?
« Reply #19 on: 19 May 2014, 05:10:39 pm »
Sorry for the delay, here are some more detailed pictures. I can't really show any more without taking things apart.
The clocks are attached to the top yoke, I don't know if the FZS has the same points as mine.
