Date: 02-05-26  Time: 11:18 am
Author Topic: Rough Idle - with video  (Read 10698 times)
Re: Rough Idle - with video
« Reply #25 on: 08 May 2014, 02:20:14 pm »
Haha, I appreciate everyones input, its just I have tried upping the idle speed before. I hope it is a solvable stutter.
Did someone say "stutter"?  :lol
johna6968
« Reply #26 on: 08 May 2014, 03:33:10 pm »
Divided opinion on whether to change float bowl gaskets or not.. Me personally I would change them, particularly if they are the originals as once flattened and then disturbed can be prone to weeping..
I've had my bowls off probably 4 or 5 times and they're still fine ;)
I did say "can" and not "will"  :D
GosportFazer
« Reply #27 on: 11 May 2014, 06:30:43 pm »
Quick Update:
Plug caps arrived and fitted - made no difference
Also received my infra red temp gun - fantastic little toy! and indeed £8
At idle from cold it seems after 5/10 minutes that the cylinders are about 160 degrees or so at header, apart from no4 which is around 200 degrees. I haven't had time to play with the mixture on 4 to see if it would bring it into line with the rest, but I also wonder at this stage whether a partially blocked idle jet would lean it out and cause the discrepancy.
Gives me something to play with on my week off anyway.
