Date: 02-05-26  Time: 08:44 am
Author Topic: Head gasket??  (Read 1863 times)
leviathanrising
Head gasket??
« on: 05 May 2014, 09:02:44 pm »
God damn it every time I seem to have fixed and run the bike something else seems to go wrong.
Now when it gets warm it decides to blow white/blue smoke after about 3 minutes running on the idle with it blowing every sec or so. It smells like partially burnt petrol so I'm assuming it can't combust enough.
My suspicions I think are confirmed given that I have a small patch of water where it seems to have leaked from the exhaust in a hairline crack (it also seems to steam from here when running). Confirmed?
humbucker88
Re: Head gasket??
« Reply #1 on: 10 May 2014, 03:51:50 pm »
Blue smoke is burning oil, white smoke is burning water. Pull the spark plugs to investigate symptoms, hopefully it's nothing bad.
Re: Head gasket??
« Reply #2 on: 11 May 2014, 09:00:41 am »
check the coolant in the header tank to see i its using any  ;)
