Date: 24-04-26  Time: 20:50 pm
Author Topic: Brake light problem  (Read 2649 times)
bigfootpete
Brake light problem
« on: 30 April 2014, 05:07:21 pm »
Just wondering if anyone has any ideas about my brake lights not working:
FZS1000, both headlights and tail lights function, but applying the hand brake or foot brake does
not activate the second filament of the brake lights bulbs.
Fuses are all ok, indicators also work fine, its just the brake lights.
I checked the wiring where it connects from the master cylinder and that appears to be ok.
BBROWN1664
Re: Brake light problem
« Reply #1 on: 30 April 2014, 05:10:38 pm »
is the bulb knackered?
bigfootpete
« Reply #2 on: 30 April 2014, 05:18:17 pm »
Nope, both bulbs are in perfect condition, filaments are intact.
Mark YPVS
« Reply #3 on: 30 April 2014, 06:23:50 pm »
Has the bulb been changed recently? if so is the new one fitted correctly , check the pin orientation as some are offset and some are straight :rolleyes
Mark  :)
bigfootpete
« Reply #4 on: 30 April 2014, 07:28:39 pm »
No, they are the original bulbs (2003)  :)
Dave48
« Reply #5 on: 30 April 2014, 07:32:38 pm »
Wiring connectors inside tail tidy? Any corrosion present? Earth ?
bigfootpete
« Reply #6 on: 30 April 2014, 09:13:56 pm »
I couldn't see the wiring, I might have to get right inside to check the wiring further.
richfzs
« Reply #7 on: 30 April 2014, 09:23:08 pm »
filament might look intact, but I've had bulbs look like that and still be knackered. Stick a new one in, ya tight foccer  :lol
bigfootpete
« Reply #8 on: 03 May 2014, 07:54:55 am »
Thanks Rich, I'll try that :-)
bigfootpete
« Reply #9 on: 04 May 2014, 09:57:16 pm »
New bulb - same problem.
I took off the rear fairing today and checked all the wiring, couldn't see any cuts or bare wires or reason why the brake lights aren't working,
also followed the wiring all the way through and even re-crimped the connections just bellow the master cylinder.
I'm taking it in on Tuesday afternoon to see if the local shop can resolve the issue.
richfzs
« Reply #10 on: 04 May 2014, 10:40:41 pm »
:-( sorry pal, worth a shot though, easy stuff first
« Reply #11 on: 04 May 2014, 10:53:45 pm »
Check your brake light switches. I had the same problem. Front one was knackered rear needed adjusting. If it's the front switch don't buy cheap ones off ebay like I have. I've had two in less than a year and it's just gone again.
