Date: 26-05-26  Time: 19:07 pm
Author Topic: Removing FSZ600 Cylinder head with engine in Situ  (Read 17166 times)
Craiginuk
Re: Removing FSZ600 Cylinder head with engine in Situ
« Reply #25 on: 10 May 2014, 11:09:30 am »
Would inlet valves from a 2001 model fit a 1999 model?
Dave48
« Reply #26 on: 10 May 2014, 11:43:49 am »
AFAIK the valve size hasn't changed between years so they should fit ok. Haynes gives all relevant specs/clearances.
His Dudeness
« Reply #27 on: 10 May 2014, 12:10:56 pm »
There's a parts manual for the 1999 model here http://foc-u.co.uk/index.php?action=downloads;sa=view;down=13
You can get the part number for the intake valve and do a search for it. You might get one cheap if you're lucky
Red Ceri
« Reply #28 on: 10 May 2014, 04:22:11 pm »
You can check all Yamaha parts for all years on the yamaha uk site here, http://www.yamaha-motor.eu/uk/services/online-parts-catalogue/index.aspx#
That'll let you know if the valves are common between years
Craiginuk
« Reply #29 on: 10 May 2014, 04:24:15 pm »
Thanks, looks like they are the same! Found some on ebay so hope to assemble in next week or so.
Craiginuk
Finally got head back together and on. Lapped all the valves too while i had it off.  But i'm having problems with the timing chain. When i tried to install tensioner it is tight even before i install spring. Did not want to force anything so slowly turned over on crank via magneto bolt. The engine bottom end turns over but cams aren't moving.
If i stick my finger against the guide where the tensioner should sit, i can feel the chain  or something moving i.e can feel something scraping. Is it possible the chain has come off the sprocket at the bottom?
Any ideas before i set fire to it?
« Reply #31 on: 30 May 2014, 08:30:32 pm »
Could of done, either that or the chain has doubled up somewhere.take the tensioner out and "jiggle"   the chain to free it, dont force anything  ;).....dont worry about the chain moving on the bottom sprocket its the marks that are important,they have to be spot on, good luck  :)
Craiginuk
« Reply #32 on: 30 May 2014, 10:41:36 pm »
Thanks for all the help guys. Time to throw in the towel. It's jumped off the sprocket at the bottom and i don't have the time to sort it now. It'll be on ebay as a spares or repair as soon as I've re assembled it all back together. A shame because it is an otherwise mint bike.
His Dudeness
« Reply #33 on: 30 May 2014, 11:26:48 pm »
That seems a bit drastic. Did you try to get it back on?
Craiginuk
« Reply #34 on: 30 May 2014, 11:41:10 pm »
Yep tried but can't get it on. I have spent way too much time on this now. Need the space in garage  for car and have a lot of work travel coming up.  I guess it is drastic but i just want rid of it now.
His Dudeness
« Reply #35 on: 30 May 2014, 11:48:00 pm »
Is it off the sprocket and bound up or is it off the sprocket and free? Could it be on the sprocket but kinked?
Craiginuk
« Reply #36 on: 30 May 2014, 11:52:33 pm »
It's off the sprocket and free. Just feels like it is turning on crank journal or smooth shaft.
His Dudeness
« Reply #37 on: 31 May 2014, 12:02:21 am »
Hasn't happened to me but I'd try hooking it back on with a wire coat hanger with a slight bend in it. It's worth another few hours trying surely! MacGyver it back on! :lol
Craiginuk
« Reply #38 on: 31 May 2014, 12:11:37 am »
Haha, yep just running out of steam. Plan was to clean carbs and sell it as i have not been using it. That turned into head off etc. will see but tempted to just sell as non runner or take to local garage to let them have a look.
« Reply #39 on: 31 May 2014, 06:43:53 am »
have one more go matey....you`ve come a long way,would be a shame to stop now when your so close to finishing..the reward of pressing the starter and it bursts into life is well worth all the hassle   :) ..600`s are selling well at the moment,easily fetch £1000....non running project maybe £300 ........
Craiginuk
« Reply #40 on: 31 May 2014, 08:20:29 am »
Cheers, will have another go.  :)  If heads not going to have to come off again at least i can get some more of the parts out of the way and back on the bike. Exhaust etc.  Have posted another question pointing to this thread in case anyone else has tried and got it right.
ChristoT
« Reply #41 on: 05 June 2014, 08:02:54 am »
As Red said: I paid 250 for mine, and the engine just needed work! Mods aside, I've spent under £400 on a stock bike. A running 6 is worth way more than that!
Craiginuk
« Reply #42 on: 06 June 2014, 02:06:07 pm »
yep she's at my friendly mechanic's for an hour or so to see if they can re fit chain and sort timing next week.  Hopefully get her running and sell as a nice bike for someone.
Craiginuk
« Reply #43 on: 18 June 2014, 08:30:06 pm »
She lives! Turned out to be a bit (lot) more than an hour, but they got chain back on, did valve clearances, refitted carbs, tank etc, oil, filter and coolant change, balanced carbs and put through MOT. I'll fetch her on Friday and will probably not want to sell:)
